Bedding rotors
My question is does it matter which set of pads I use to bed the new rotors?
Because to my understanding bedding is to get a layer of pad material on the rotors and I'm worried that if i bed them with r4s it will decrease the performance when I put the XTs back on. Or does it not matter and i just need to re-bed them after the switch?
Brake rotors and pads both develop grooves over time. Brand new surfaces will mate perfectly. However, if you have previously worn rotors, which you will when you install the XT's, the rotors will have already developed "hills and valleys", per se, from the R4s pads. Therefore, you'll have to mate the flat XT pads to the grooved rotors. It's fine I guess, but it'll just take you a while to do so as the pad will not be making 100% contact with the rotor until the hills and valleys have been worn into the XT pads.
Kind of a ramble, I know.
Make sense?
In theory, what you mentioned in your OP is totally doable. You'll just have to take a while to bed in the XT pads (30+ high speed brake slams until 10 mph) and you'll reduce their life.
When my buddy swapped new Endless MX72's on his S4, he said they needed about half a track days worth of abuse/heat to feel completely settled into the previously used rotors.
Make sense?
I didn't look through that other link roadkillrob posted but Stoptech has a decent white paper on it.
http://www.stoptech.com/technical-su...ake-pad-bed-in
You can also repeat this process later on if you end up with glazing. It can happen on a street driven car.
Like I said, not necessarily a big deal, but something to be cognizant about when thinking about doing this.
When track pads are cold they will scrub the rotors and get rid of any material transfer, even if it's from the same pads. In other words, even if you put on new rotors and a set of track pads and bed them in properly until you have a nice material transfer film on the rotors, you will completely scrub them off in a couple of days of street driving. And, I've never seen a heavily worn "grooved" rotor that wasn't cross-drilled, so the RBs will in all likelyhood be just fine and wear much more evenly than OEM rotors. Yes, you will have some fine grooving, but it will take all of one or two days for the new pads to wear down the high spots until the entire pad surface touches the rotor. I haven't used the XT pads, but if they are like most other track pads, keep in mind that even after they're bedded in, they will continue to scrub off their own pad material from the rotors during street use and you'll need to heat them up again to get pad material transfer back on the rotor before every track day.
So - feel free ot use the R4s in the winter, then put the XTs on in the spring, DRIVE CAREFULLY AND SLOWLY for the first few days (you won't have a lot of stopping power and also you don't want material transfter from the XTs - you only want to scrub the rotors from the R4s), and when they start to squeal you can bed them in by bringing them up to temperature. Repeat as necessary.
The only scenario where there is a potential for problems is if you use a mild "street" pad at the track and overheat it. You'll get a lot of material transfer on the rotors, and that's when you really need to get it all scrubbed off before bedding in the new pads because the new (even hotter) pads will smear and bake this material on even more, resulting in build up on the rotors and nasty vibration.
Another DIY on scrubbing off baked-on pad deposits from StopTech: http://stoptech.com/technical-suppor...eposit-removal. It essentially says how to scrub the rotors using the more aggressive pads, in your case the XTs. And, just to be sure, I'd contact Johann at RB and ask if the 910s are abrasive when cold. We were chatting for quite a while when I bought mine and he certianly seems to know his stuff. Bottom line is - pretty much any set of pads (no matter how mild) will scrub the rotors clean over time if you don't periodically get them nice and hot.
