Bricked ECU
I did something similar...felt stupid but everything got sorted out at the end.
Edit - I did send my ECU to EC first and Jerry opened it up to see if he could flash it back, but was unsuccessful. That's when I resorted to having it towed to the dealer. You may get lucky and not have to.
OP - EC may be able to send you a stock map that might be able to recover the ECU, but in my case it didn't work and I had to tow my car to the dealer. Both, EC and the dealer were very helpful.
"Hey, my car is running rough, what's wrong?"
"Oh, it's definitely [insert answer here]. Happened to me, my car was running rough too."
At no point did they ask me about my battery or tell me to hook it up to a charger.
The whole process takes about 10 mins...our fans will go on for a minute or two and if that kills your battery or affects your voltage, your battery is probably well overdue for change.
...After Eurocharged already stepping in to help to OP solve his problem.
...Which he did the EC way and spent precisely $0 at the dealership to get his car back on the road.
Sorry you had to go through that experience though. Must have been frustrating running your car all over the place.
OP -- You get out there for a drive yet? Any thoughts? Not sure where you are located but keep in mind that just because there is no snow on the road it doesn't mean you should just romp on it, especially if it is cold. Someone else already had to learn recently that temps effect tire performance and not just what is on the road.
OP - glad you came out unscathed. You are one of the lucky ones.
It must depend on what process it's at when loading the tune. Do you remember if it was during the actual write process (when you see the progress bar and the fan is running)?
I can understand one gets excited during the install...but damn, strap yourself down man.
