C63 AMG (W204) 2008 - 2015
Looking for some bumper part help
Old Dec 22, 2016 | 10:00 PM
tantumaude's Avatar
S211 E55, R129 SL500 + others
Hi everyone. My new (to me) 2009 seems to have lost a duel with a reversing semi. I'm in search of a few parts to fix her up.
I'm a bit ashamed to admit that I haven't really been able to figure out the MB parts catalogues. I put in my car info and I get several results for many of the parts, none of which are said to be explicitly correct for my car. I think I've narrowed a few down, but I'd like some help, especially regarding the front bumper.
My car is a 2009, it has no PDC/park assist but appears to have headlight washers (I assume the nozzles under the headlights refer to this). As far as I can tell, I'm looking for 2048855125. I've seen some for sale with and without some plastic brackets behind the upper left and right sides. The local dealership tells me that in 2012 the bumper design changed, and these plastic pieces were no longer included as part of the cover itself, but my 2009 should have them as an integral part of the, well, part.
Anyhow, if anyone has any leads on a used bumper cover, or, even more helpfully, all the trim pieces and various bracketry that makes up the front bumper assembly, I'd be very grateful. Dealer wants $2400 for the cover alone, which I find a bit pricey. I'm also looking for a driver's side rocker panel cover (the plastic trim piece). I'm located in Oakville, Ontario, Canada.
Thanks in advance.
Old Dec 23, 2016 | 01:31 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
You can find aftermarket. http://www.andysautosport.com/ they have a poly replacement bumper, which is better than fiberglass. You have to pay the get it painted, primed, installed though.
rockauto.com could have some parts
just throwing stuff at you, hopefully it might help.
Old Dec 23, 2016 | 03:38 PM
tantumaude's Avatar
Thanks for the links. I'm trying to stay as OEM as possible (have had some very bad experiences before with aftermarket parts). A forum member seems to have a bumper assembly for me (right color too!), but I'll likely be using rockauto for the bracketry.
Old Dec 23, 2016 | 04:17 PM
Valvestud's Avatar
2014 E63 AMGs, 2015 F-150 Lariat, 2010 Porsche C4S
If you provide your VIN, I can post back pictures and part numbers of the assembly or assemblies.
Regards,
Joe
Old Dec 23, 2016 | 04:41 PM
tantumaude's Avatar
Thanks Joe. WDDGF77X89F278699
Old Dec 23, 2016 | 06:31 PM
Valvestud's Avatar
Here you go, Let me know if you need anything else. Also note that any parts in picture that are grayed out do not apply to your car.
File Type: pdf
File Type: pdf
Old Jan 30, 2017 | 09:42 PM
tantumaude's Avatar
Pursuant to the above, my replacement bumper cover doesn't include part no. 16 in the diagram. Is there any way to find out what part number it is so that I can order it?
Old Jan 31, 2017 | 01:42 AM
Valvestud's Avatar
Post the VIN from a car that has that part, and I'll look it up.
Old Jan 31, 2017 | 09:46 AM
tantumaude's Avatar
WDDGF7HBXDA748126
Old Jan 31, 2017 | 09:52 AM
Valvestud's Avatar
Left is A 204 885 47 65
Right is A 204 885 48 65
Regards,
Joe
