C63 AMG (W204) 2008 - 2015
Question: Replacing the lower grill
Old Jan 11, 2017 | 11:23 AM
SuperFastYo's Avatar
C63 AMG - LSD
My lower left grill got hit by a rock and took a nice chunk out of it. I ordered the part but was curious if anyone knows if I can use a pry tool to get it out or if I have to remove the bumper. I'm hoping for the first since I'm extremely lazy
I know the middle needs the whole bumper off, but not sure bout the little side ones.
Old Jan 11, 2017 | 11:26 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
For FL cars, you have to remove the DRL surround to access 2 of the screws. There are 4 T25 (T20 maybe?) torx screws, one on each corner. Super easy.
Old Jan 11, 2017 | 11:28 AM
C63 AMG - LSD
Okay, PFL is probably similar. I'll check it out when I get home, thanks Blk!
Old Jan 11, 2017 | 12:37 PM
chrisridebike8's Avatar
'10 C63
For that one, you might be able to pull the fender liner and access the tabs. I don't remember there being any screws on the lower grilles when I replaced mine. I'll be honest though. It's been awhile since I replaced mine or peeked behind the fender liners.
Old Jan 11, 2017 | 12:43 PM
C63 AMG - LSD
That may be the easiest option. Ill update once I find out.
Old Jan 13, 2017 | 07:10 AM
kimeran's Avatar
2012 C63 AMG, 1991 325iS. Ex: 2011 C63 P31
I need to replace mine as well.
It looks like I should be able to replace it by taking out the cover under the car and accessing the clips from there.
Need to use a lift of course.
Will let you know once I do it
Old Jan 13, 2017 | 09:09 AM
manuelsm's Avatar
C63 amg
i replaced mine without removing anything just pulling the old one out through the hole and installing the other one.
Old Jan 13, 2017 | 09:11 AM
C63 AMG - LSD
Really? That's what I was hoping for. Haven't had a chance since cali finally got a bit of rain and I havent felt like screwing around with a wet car.
Old Jan 13, 2017 | 09:55 AM
'10 C63
I hate those lower grilles. I swear they are made of toothpicks. They break all the time. Mine have broken 3 times. On my lexus, they never broke in 212k...and I hit an armadillo once!
Old Jan 13, 2017 | 10:05 AM
C63 AMG - LSD
Yea, they're way thinner than I thought they would be. First time I've ever had to replace a grill on a car. At least they're (somewhat) cheap.
