C63 AMG (W204) 2008 - 2015
anyone in dfw with a STARDAS that can help?
Old 01-12-2017, 05:06 PM
bluejae's Avatar
'10 C63
need to run some test/diagnostics and apparently i need stardas to do it... if there is someone local who can assist, i would really appreciate it...
Old 01-12-2017, 10:09 PM
roadtalontsi's Avatar
10 C six trizzle
what exactly do you need?
Old 01-13-2017, 11:08 AM
bluejae's Avatar
'10 C63
i need to clear my transmission adaptations and then do an upshift/downshift adaptation.
Old 01-13-2017, 11:19 AM
Jasonoff's Avatar
Received 1,580 Likes on 931 Posts
2010 C63 AMG
Doesn't that happen when you do the reset procedure?
Or is the STAR diagnostic more thorough?
Old 01-13-2017, 11:27 AM
bluejae's Avatar
'10 C63
i've read about the reset procedure but i've only really confirmed by owners of other models... i don't think i've seen anyone actually 100% confirm that it works on the w204/c63... but i've tried it and have never been able to tell anything...
i believe the stardas thing is more thorough... it needs to be connected to the car while it's driving and going through the gears.
Old 01-15-2017, 06:48 AM
dubzAMG's Avatar
2010 C63 AMG FBO, 2014 E63 AMG S
bluejay,what kind of issues are you having with your transmission?
Old 01-16-2017, 01:55 AM
10 C six trizzle
resetting the shift adaptations isn't going to fix a problem. there is no point. if you have a problem you have a problem. The car naturally adapts as you drive it. it doesn't "learn" problems, it tries to compensate for problems, however it can only compensate so much until it cant any further. 2-3 slipping under full throttle? that's the weak point.
Old 01-16-2017, 12:58 PM
bluejae's Avatar
'10 C63
i've had issues since 2010. they may be related or not. i'm not exactly sure. originally it used to be a hiccup feeling while the car was still cold and i gradually gained speed. it would usually happen in higher gears 5-6 or 6-7. usually while getting on the highway in the morning and increasing speed on the on ramp. but then that problem went away a couple years later and then this issue between 2-3 shift in C mode. and i believe 1-2 or 2-3 shift in S mode. and this i could never replicate consistently. it was somewhat random.
it has never happened under full throttle. it's usually somewhere around mid throttle increasing speed after a stop such as from a red light or stop sign. but it also happens after slowing down for a right turn and then speeding back up. so the car doesn't need to be at full stop for this to occur.
i've taken it to the dealer before regarding this and of course they were not able to replicate the issue. and now i'm out of warranty and still don't know how to fix this.
Old 01-27-2017, 11:39 AM
bluejae's Avatar
'10 C63
bump
Quick Reply: anyone in dfw with a STARDAS that can help?
