FlexFuel for Everyone! Eurocharged ATX E85 Kits NOW AVAILABLE :)
If you have Longtubes (and need injectors) we can supply new Bosch injectors, or we can put you in touch with the company. As stated before, WE ARE NOT looking to make money on the injectors, so know you will be getting the best possible price
Please PM me on here, or call the shop at 512-777-2799 to discuss options and pricing
Thanks a lot!
Dave
Bottom line is that the kit price will be for the kit and WON'T include injectors.
HOWEVER - if you have longtubes, you *MUST* run at least 550cc or you will run out of fuel at the top. So! The solution is that we will be offering brand new Bosch injectors in lieu of the previous ported ones. The reason for the core program was obviously to keep the cost as low as possible... so naturally the price of new injectors will reflect a slight increase. As before, we wont be looking to make any money on the injectors, just covering our costs. We sold the last kit today at the "launch price" so I wanted to announce the new pricing:
$1,600 shipped for the system, and it will **not** include injectors.
Still finalizing the numbers - and trying to keep pricing as close as possible. but it looks like the injectors will come in at just under $500 for a set.
Then : If you needed injectors, and elected to keep yours, you would be spending $1,950 ($1,600 +$350 core)
Now : You spend about $150 more, keep your stocks, and get brand new injectors. I think its a win for most everyone, as we have found that most just want to keep theirs anyhow.
*******If you DON'T have longtubes - kit price is just $1,600*********
Still happy to help you out with injectors should you decide to go with longtubes later (AND I'm happy to help with the LTH as well for that matter)
Thanks for following the developments! I look froward to more systems getting onto cars, and more folks finding all that lost power that's missing without running E85
Dave
Dave
Thanks!
Dave
Are you going to do a before and after dyno.
Also any recommendation on a more affordable air box upgrade? I don't need the seemingly standard carbon fiber, I would rather get a plastic one for less $ since nobody will ever see it. Thanks!
You don't need a tune, you can get this kit, install it WITHOUT a tune and it will work great and you'll make more power.
I can do a package deal with a tune/hand-held and some ROW Air Boxes (what I would recommend) for you if you would like.
Please PM me and we'll work something out for sure!
Thanks a lot. If you go with longtubes - you will need to upgrade your injectors, but we have that all squared away now
Dave
Thought about this, but E85 isn't readily available enough here, and I don't have the trunk space to carry 80gal of the stuff with me for trackdays. 44O and race fuel and I'm more than good for now thanks!
Also,how many degree's of additional timing does it generally allow a motor with headers to run?
First 30 to purchase the FlexKit will get the "HotMap" (what I just named it) for free.
After that - $35 for the map.
Remember - you will be treating this map just like any other race gas map... ONLY to be used with Ethanol.
Thanks!
Dave
Dang - price on that must be wicked high.... Ethanol also gives you more power than race gas, AND cools the engine BETTER than 44O. Not to mention costing under $2 a gallon... how much is that MS109? $15-20/gallon?
just sayin'
Dave
I'm almost tempted now that my car is a lot happier. I'll be in touch. I think I'm also going to want you to make me a kit for my other car too that we discussed in the PM. I just need more positive reviews to get me on the bandwagon
Ethanol is NOT a replacement for better coolers. There are certain benefits for sure, and the power bump is nice (not enough power isn't my most pressing issue), but that statement is just flat out wrong.
$8/gal at the track and I usually go through ~40gal on a weekend. Beats towing a trailer with 80gal of E85.
You're probably looking at an additional 10whp or so with the "HotMap"
I would 100% get a handheld, you can re-flash your car on the side of the road. SUPER easy to use. Still a very good power increase without the "HotTune". I would be surprised if you didn't break into the 500's at the wheels.
Thanks!
Dave
how does this kit work with bigger injectors without a tune on normal gas.wint it run rich with bigger injectors?
We have tested the theory of larger injectors/running rich for a few thousand miles, obviously it would show up within the first tank if waas going to be a problem by simply looking at fuel trims. On all test cars trims are good, and no check engine lights for mixture adaptation. The reason it doesn't run rich (you may know this already) is that the system works from a Target AFR (or Lambda) and the injector PW is modified (trimming) to get to that target. you have "Short Term" and "Long Term" fuel trims, each working in blocks, if short term has to go up 25 units (for example), this will effect the long term by 1 unit. After this, Short Term resets to "0" and mixture is checked to see if moving it up 1 unit got us to "Target AFR". There is a pretty good margin on the M156 where we can do this. That't the long answer, but should tell you what you need to know.
Thanks!
Dave
