C63 AMG (W204) 2008 - 2015
Transmission problem
Old Feb 3, 2017 | 07:40 AM
Serzhant's Avatar
2013 C63 AMG
I bought a 2013 C63 AMG with the P31 package a few months ago, CPO, and so far it's been great however I noticed that when I put the car in reverse it has a hard time finding the gear. It'll put it in reverse and the car will go backwards but when I put my foot down on the gas nothing happens until 2-3 seconds later it "finds the gear". This doesn't always happen except in the mornings when the engine is cold and sometimes it'll happen during the day even when the cars been running for a bit. Anyone else have this problem or should I take it to MB?
Old Feb 3, 2017 | 08:00 AM
Serzhant's Avatar
2013 C63 AMG
Thanks. Yeah I only thought it happens when the engine and fluid was cold but the engine was at about 210 degrees yesterday and it still happened.
Old Feb 3, 2017 | 08:42 AM
DP8's Avatar
DP8
E90 M3, '13 C63 Sedan
Not sure how bad/long the hesitation is but a slight hesitation is fairly common on the MCT transmission when first starting the car and shifting into reverse and into drive at low speeds. My car also has a slight hesitation before it finds the gear when I first start up the car. I've sort of gotten used to it so I can't remember if it's happened to me after having driven for a a while but generally it's only when I first start the car up. I searched on this forum and there were quite a few people who had the same experience and I think a slight hesitation is normal. I also have a 2013 P31.
Old Feb 3, 2017 | 08:49 AM
Serzhant's Avatar
2013 C63 AMG
This sounds like what's happening to me. The hesitation lasts as long as 3 seconds though for me sometimes.
Old Feb 3, 2017 | 08:51 AM
Adam Chambers's Avatar
2014 C63 Sedan (SOLD), 2011 SLS Gullwing (SOLD), 2009 SLK55 (SOLD), 2015 C7 Z06 7MT, 2016 C450amg
MY 14 doesnt have issues finding reverse, but going from reverse to drive there is a slight delay. Like you wouldnt want to back out into a busy road and think you can put it in drive and get out of the way quickly.
Old Feb 3, 2017 | 09:32 AM
Conv_GSDriver's Avatar
'18 Audi A4
Yes I am experiencing the same slight hesitation in the same areas all of you are describing. It happens in normal driving when at a stop light, the car is warm an in use and when giving gas takes a slight second to grab and go.
Old Feb 3, 2017 | 10:04 AM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
It was established in regular w204 forum that the thing is common and theres nothing really to worry about. Just annoying.
Old Feb 3, 2017 | 10:06 AM
jmueller's Avatar
Jag F-Type V8
I had a 2012 and it would take 2 seconds to go into reverse even after being fully warmed up. I always back into my parking space at home and it would take a solid two seconds to lock into R. Anything much longer than that and I would be all over the dealer. Sounds $$$$$$$$ in a bad way.
Old Feb 3, 2017 | 02:13 PM
gogoquadzilla's Avatar
2012 C63 AMG P31
This is a very common problem, no doubt. Mine does it, too. I'm not sure if anyone has really related it to any other serious failures, though.
Old Feb 9, 2017 | 09:16 PM
minchu0647's Avatar
c63 amg
Ha everyone has similar problems. Mine does in cold when switching from R to D, takes like 2 sec. I could even hear the gear is being engaged. so loud.
Old Feb 9, 2017 | 09:18 PM
C SEXY 3's Avatar
2006 E350 (SOLD), 2010 C63 AMG
Yup, same exact thing for me.
Old Feb 9, 2017 | 09:32 PM
Sick AF's Avatar
'12 C63 Coupe
Same here.
Old Feb 10, 2017 | 11:04 AM
Patel's Avatar
2013 C63 AMG Sedan, 2015 GLK350
I've also experienced the same sensation. First time was cold, reversing out of my driveway then trying to go into drive, taped the throttle to early and felt like I was clunking into drive... Maybe because I was in comfort. Now I just take my time waiting after going into reverse or drive.
-Patel
Old Feb 10, 2017 | 11:47 AM
C SEXY 3's Avatar
-Patel
Yup just have to wait a second when shifting from R to D, don't notice it that much unless I am in a hurry.
Old Feb 10, 2017 | 06:56 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Same here, I find it is a little better if I come to a real solid stop backing up before I put it in gear, but cold I do get a little lag from R to D in my 2013.
Old Feb 11, 2017 | 12:20 AM
simandang's Avatar
G63/RR LWB/W222 S550
Mine does this too. 2013 non p31. Sometimes it clunks when it "finds" the great. I have learned to avoid it by giving it those few seconds it needs and now when it happens its usually my fault when I am in a rush and quickly shift and gas it without it being in gear, then it clunks and goes into gear.
We have a new audi A6 that is CVT and it behaves similar and does weird things when cold. You have to be patient with that car as well.
