C63 AMG (W204) 2008 - 2015
Group Buy: DSS - Carbon Fiber Driveshaft
Old Sep 19, 2018 | 05:40 PM
  #226
Crya's Avatar
2009 C63 P30
Originally Posted by JohnnyC
Has anyone thought about the responsiveness change is a direct result of losing the rubber guibo (flex disc)? We already know the carbon driveshafts are NOT light weight from the suppliers. I have a feeling putting an aluminium plate where the guibo was would give you the same feel.
Do it and report back. There are two discs right? Gotta be less than a shaft.
Old Sep 19, 2018 | 06:54 PM
  #227
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
The carbon driveshaft itself cushions the drivetrain more than the aluminum one. The dynamics are just totally different - think of the carbon driveshaft as a spring that winds and unwinds a bit, while at the same time providing a more direct feel.
Good luck making the aluminum disc/plate and fastening it then balancing it adequately. Let us know how that works out. Sounds like way more trouble than it’s worth, and there are probably safer areas to experiment rigging something together on your car.
Old Nov 27, 2018 | 07:43 PM
  #228
MBNRG's Avatar
Originally Posted by kjkidd21
SOOOO... I got my driveshaft installed on Friday... (DSS shipped mine first because I organized the GB)...
The obligatory pics:
For those sliding around with the DSS CF Driveshaft, in what orientation did you install the Driveshaft?
Lee at DSS recommends in our C63 application for the CV joint end to mate with the Trans side, and the U-Joint to mate with the Rear Differential side.
But as seen in Kevin's photos above, his installer chose an opposite orientation.
Those with a similar orientation as Kevin's above - why did you/installer choose CV joint end to mate with Rear Diff side?
Old Dec 20, 2018 | 06:00 PM
  #229
Crya's Avatar
2009 C63 P30
Curious which way you ended up installing? Did you ever get any replies?
Old Dec 21, 2018 | 11:45 AM
  #230
blackbenzz's Avatar
haters crazy
The pics show incorrect installation. I was probably the first to put a custom DSS CF shaft on an AMG (CLK55) and it looks very similar to this shaft and it installs opposite to the pictures.
If there is enough interest I can put together another group buy
Old Dec 21, 2018 | 02:21 PM
  #231
MBNRG's Avatar
I will be installing per Lee's and Ahmad's recommendations: CV joint end to mate with the Trans side, and the U-Joint to mate with the Rear Differential side.
Love the ECE Mounts, btw Ahmad
Old Dec 21, 2018 | 02:52 PM
  #232
blackbenzz's Avatar
haters crazy
Happy to hear!
Old Dec 21, 2018 | 03:30 PM
  #233
Crya's Avatar
2009 C63 P30
DO IT! I tried to organize one and failed over the summer. DSS was doing it at 10% but another vendor already sells at that discount. If you can do more and shipping I bet there’s interest!
And the mounts too! I need a sale to pull the trigger lol!
Old Mar 9, 2019 | 09:29 PM
  #234
sqitis's Avatar
C63 P31
Any news on this yet?
Old Mar 9, 2019 | 10:56 PM
  #235
Crya's Avatar
2009 C63 P30
Best price still seems to be at Race Consulting Agency unless the fine people at ECE end up doing better but I think this lost momentum. I was just thinking about it however as there suddenly seems to be a lot of new blood that came in the past few months. Maybe there will be renewed interest!
Old Mar 10, 2019 | 08:44 AM
  #236
sqitis's Avatar
C63 P31
Hmm, well I'm trying to track down this weird noise in the rear that sounds like a wheel bearing but I replaced the passenger rear and the noise was still there. Now I'm thinking it may be that center bearing and was wondering about replacing the whole shaft and be over it......
Old Mar 10, 2019 | 06:50 PM
  #237
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
Ran a DSS CF driveshaft on this car. Confirmed dyno at 650HP.
Old Mar 12, 2019 | 08:24 AM
  #238
63 Molar's Avatar
C63 AMG
Any lads in Australia fitted a CF shaft .???
Old Mar 12, 2019 | 10:35 AM
  #239
sara_judjin's Avatar
Mercedes-Benz SLC
Thanks @63 Molar
Old Mar 13, 2019 | 05:08 PM
  #240
Connor Xiong's Avatar
C63 W204
In for the buy if we get a group sale going again. Somehow mine got bent.
Old Mar 13, 2019 | 07:12 PM
  #241
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
your stock one did or your carbon driveshaft did?
Old Mar 13, 2019 | 07:14 PM
  #242
C63 W204
Stock, Also I checked and the OEM one from Mercedes is back ordered.
Old Mar 13, 2019 | 07:18 PM
  #243
AMGonFire's Avatar
i Snaped mine in half don’t feel bad
Old Mar 13, 2019 | 08:27 PM
  #244
63 Molar's Avatar
C63 AMG
+1 on that my man. Ima keen
MC
Old Mar 13, 2019 | 08:29 PM
  #245
63 Molar's Avatar
C63 AMG
Hey man,
Your one of the main players on this forum. Please confirm you don' regret purchasing your CF drivershaft ? Ima long way from the great USA, if I have problems. Down under in Australia, I don't believe anyway has committed to this upgrade.
MC
Old Mar 14, 2019 | 05:20 PM
  #246
BLKSHRK's Avatar
C63 AMG
I would be in for another group buy
Old Jan 3, 2020 | 08:28 PM
  #247
Crya's Avatar
2009 C63 P30
Torque Specs
Anyone recall what the torque specs are or willing to look up for bolting in this piece?
A few years back Vladds posted it was an easy install only requiring a few wrenches. So no removal of exhaust piping etc to get up in there? Cheers
Old Jan 3, 2020 | 08:57 PM
  #248
MBNRG's Avatar
Ensure that CV end mates to Transmission side; U-joint flange mates to the Rear Diff side.
Per Lee Mejia of DSS:
3 x 12mm bolts that go through the factory flanges on both ends will be 70 ft-lbs, the 6 x 10mm bolts that attach the CV to the front adapter are 57 ft-lbs, and the 4 x 3/8 bolts at the differential adapter are 54 ft-lbs. We recommend blue Loctite on the threads as well.
After bolting it on, check the Driveshaft CV clearance
to ensure it is within 3.25 - 3.75 inches as posted on their website.
Old Jan 3, 2020 | 09:05 PM
  #249
BLKROKT's Avatar
100% you need to take the exhaust down from the headers back to the resonator at least depending on what you have under there. Look at the pic below - it’s blocking access to the driveshaft completely. I don’t see a way to do it without taking the exhaust off.
Old Jan 3, 2020 | 09:18 PM
  #250
Crya's Avatar
2009 C63 P30
Right on thanks. I guess this raises another question for as I wasn’t aware of the additional adapters. Is there a sequence in which all this gets tightened up? Better left to a pro? Or does it all make sense once the old shaft is off and the DSS unit is going in. Sorry for the confusion I just thought there were basically the two ends bolting to the diff and trans and bingo.
