Hey guys. I tried to install 12mm spacers on the rear on my C63 507 coupe stock 19" wheels. I was having any issue with the hubcentreic pushing the centre cap out and not sitting flush with the wheel.
I was thinking of putting 12mm around. Has anyone else run into this issue? And what do you guys recommend for spacer size for the front and rears.
I havent tried them in the front yet.
heres a pic of the spacer I tried.
This is a h&r spacer.
It looks like somebody welded something to your spacer. Did you buy used? Because the lip that they come with isn't more than 1/2" high. That's the problem.
Should th top of the spacer be open. This one is closed. I borrowed it from a friend.
Thanks BLKROKT.
Any chance you know the H&R part numbers (or how I would look them up) for the 12mm spacer kit and 40mm bolts that would fit 507 Edition OEM Wheels.
I can't tell this from H&R's site.
