Help with C63 Black Series Replacement Brakes (Pads and Rotors)
I've been doing some research into replacement brakes (pads and rotors) for my black series, either OEM or aftermarket and I wanted to throw this question out there. I'm finding that a lot of the info I've been seeing is limited, old, or brake upgrades for standard AMGs to black series spec brakes.
Anyways, is there any good alternatives to OEM? I've seen RB floating around with Girodisc, with the latter being the better manufacturer. Additionally, are there any sites that sell OEM parts for less than normal prices? I had an e60 M5 where I was able to buy rotors online (from the midwest) that were I think $200 to $300 less a piece than normal dealer pricing. I'm curious if there's something like that for Mercedes. I know with the black series, I really won't be able to get away from the high cost of parts, but I might as well try to save a few bucks when I can when getting OEM parts.
Thanks for any help!
Double check me here, but I'm pretty sure black series fronts are 2304211212 used across a couple of AMGs.
http://www.ebay.com/itm/Mercedes-CLS63-SL55-SL63-SL65-AMG-Pair-Set-of-2-Front-Disc-Brake-Rotors-Brembo-/361911833324
edit: wrong about the rears
AutohausAZ
http://www.autohausaz.com/pn/2194210212OE
Lists the P/N as 2194210212OE. And it specifically stated for the BS.
Parts.com
https://parts.com/index.cfm?fuseacti...-Caliper-ROTOR
Lists the P/N as 2124210512. Also specifically stated as a BS rotor.
FCP Euro
https://www.fcpeuro.com/products/mer...mbo-2304211212
Lists the P/N as the dealer... A2304211212. And the Brembo version is the same as what you stated Realjones88.
I haven't even looked at the rear rotors yet.
Overall... confusing, lol. What sucks is that I can't seem to find a place that sells just the rotors, not the whole set (rotor and hat). I would imagine that's all I need and would save a little bit off the top. But, seeing the part number that connects OE and OEM from Brembo, I may just get the Brembo versions.
Too bad upgrading to ceramics is the equivalent to buying a new cheap car, haha.
2124210512 = 360mm '1.5' piece rotor for p31 C63
A2304211212 = 390mm two piece black series rotor, also found on higher class AMGs
The two piece rotors are also stamped 360 or 390 if you see an actual picture of them.
Measure your current rotors, you might just needs pads as well.
On my car the pads will need to be replaced soon, but the rotors still have nearly 2mm of wear left.
--Kyle
Doing some reasearch about replacing brakes, found this thread. I'm getting close to changing my brake pads, and I was wondering if I have to change anything else with it - like rotors, discs, ABS sensors. Everything is working just fine. My car has around 14kish miles. I'm not sure if I MUST do it right now, but as I live in Brazil, and parts here are often extremely overpriced (specially for this car), I like to plan myself ahead.
Many thanks in advance.
I changed my rear pads alone... not very hard to do. Since they're Brembo brakes, they're pretty standard among a lot of performance cars and thus, instructions can be found easily online. Also, I found the part numbers for the pads and ended up buying the OE pads on eBay for a much cheaper price (non-MB branded, but the same manufacturer). One of the manufacturers is Jurid (it took me quite a while to confirm that). In any case, do your own research and ensure you understand what you're buying and doing (if you end up changing out the pads yourself).
Thanks very much for the feedback, my friend!
My doubt was about the brake pad sensors, and it seems that it’s interesting to change them when I change the brake pads.
