Shell Rotella T6 New Formulation
Remember these vids?
EDIT:
my engine sounds like yours, and most M156's i've seen on youtube sound the same. as mentioned i already replaced lifters so that rules those out. My lifters actually looked fine when removed. a little more wear than normal, but could easily have gone another 30-40k. glad i changed them out though. safe mind, safe heart.
There was absolutely nothing wrong with my buckets last year when I did the head bolts.
So AMG knew that there's work to be done.
Mines are the second oldest part number.
Oddly there's another thing, where the first generation adjusters can be sent back to AMG for reconditioning.
The current (to my knowledge) part number is A 156 050 36 47
I think that both left and right have the same part number, so to overhaul the engine you'd buy two
However, for the exhaust, if I'm right, A 156 050 37 47 is the current part number for TWO of them. You buy this, you get both.
Now my recollection was partially wrong, meaning, the note reads that repair in collaboration with AMG is possible up to engine number 60 001126, so goes not by part number of the unit, but by engine number.
Now the part numbers for this, if I have it right are in order of supersession:
156-050-18-47, 156-050-29-47, 156-050-30-47, 156-050-33-47, 156-050-35-47
So if I'm right you're ahead of me, but still only in the middle of the line.
Again, when reading the above, I'm not a parts professional so this is only best guess, don't buy parts based on what I write, buy them based on consulting with parts professionals.
Replaces:156-050-18-47, 156-050-29-47, 156-050-30-47, 156-050-33-47, 156-050-35-47
Any concerns that it is so thick when cold?
Spec sheet:
https://www.purseroil.com/wp-content/uploads/pdf/ShellRotellaT65W-40.pdf
Terms and Conditions: Offer ends 12/31/18. Valid at participating retailers in the US only. Void for residents of RI or where prohibited, taxed, or otherwise restricted by law. Limit 4 rebates per person, household or address (email and physical). Mail-in requests must be postmarked by 1/15/19 and received by 1/31/19. Online requests must be received by 1/15/19.
https://images-na.ssl-images-amazon....500159454_.pdf
https://shop.advanceautoparts.com/p/...264/11601386-P
Im austin and will be picking up my new to me W204 C63 2011. Car has 70k on it and has always been serviced at the dealer which gives me the scaries. When I pick it up what do you guys think is the best oil for these cars? Do I need any additives like ceratec? Ive been reading alot but have yet to find what has truly worked best for people. I live in Pennsylvania and the car will be my daily. Thank you for your advice!
