HELP!!! P2540 Code
I replaced the main fuel pump on the car (Driver Side) then drove it approx. 10 miles and the light came back on. Came up the same P2540 code. I then started watching the fuel pressure with the scanner and found that the fuel pressure was not dropping off when it shifted as it did before.
I am leaving to go to Myrtle Beach on Monday.
Can anyone help me with figuring this out???
I have attached pictures of the fuel pressure before and after replacing the fuel pump, this is from 0-90 MPH on both graphs as you can see one is choppy and the other is smoother until I let out of the throttle.
Thanks,
Matt
I'd PM the OPs in the threads below and see if they got their issue sorted. Maybe ask them to reply on the tread they created (for help) with the solution?
https://mbworld.org/forums/c63-amg-w...ode-p2540.html
https://mbworld.org/forums/c63-amg-w...uel-sytem.html
