Help Please - Puffing smoke smells like gas.
Well, coming home it was over 100 degrees. I'd pulled off the freeway to grab some grub. I pulled out and while sitting at a light. The idle become really rough and it seemed like I dropped a cylinder. I limped it home ok on flat spots but if there was a little bit of a grade it really started to show.
Got it home and noticed that it was puffing smoke on the passenger side and that it smelled like fuel.
Here's what I've done:
- Checked the plugs on the pass side and they're all fine.
- Ordered new ROW tops with new MAFS
- Ordered 2 new coil packs
- Ordered a new MAP sensor
I'm hoping that one or all of these will fix the issue. If it's the head bolt issue. Well, guess I'll be taking the heads off and doing that.
Here's what my scanner shows. Thoughts?
Thank you for any help that might be offered.
'08-'11 sometimes later. You can check the "Q" number on the injector.
The misfires are a result of a mixture error don't pay attention to them. The MAF could be related to the MAP or maybe you have a bad intake leak.
