C63 AMG (W204) 2008 - 2015
Radar detector install using dashboard fuse box?
Old Jul 28, 2017 | 03:51 PM
Mr.McGibblets's Avatar
2013 C63 AMG Coupe
OK, I've been searching here and on the web for the past few days, but no luck.
I'd like to install my Escort radar detector into my USA-spec 2013 C63 Coupe using the interior fuse box located on the driver side of the dashboard. Some W204 owners say that they don't have one, but I do. It's totally empty except for on 10-Amp fuse located in slot #123. See the pics I took below.
Has anyone tried using this fuse box to wire an accessory?
Does anyone know what the single 10-amp fuse in slot #123 is for?
I'm assuming all of the other slots are live (I didn't have time to check with my voltmeter, but I will soon) and therefore I can use any slot with items shown below.
Old Jul 28, 2017 | 03:59 PM
chrisridebike8's Avatar
'10 C63
I used the fuse box in the trunk and used an add a circuit fuse tap like you have pictured.
Old Jul 28, 2017 | 04:11 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I used the one on the drivers side for my dashcam - several of the slots have power, some all the time some switched with the key on mine, just check with a volt meter and then use an add a circuit fuse (i used the type in your pic with the red short wire), totally beats wiring to the back of the car!
Old Jul 28, 2017 | 04:13 PM
bhamg's Avatar
C63 AMG
I say go for it. IIRC I read some years that the peak draw of an Escort (don't remember which one) was measured at under 200mA.
Old Jul 28, 2017 | 04:15 PM
2013 C63 AMG Coupe
Perfect! Thanks for the confirmation! Wiring job will be nice and easy.
How did you route around the A-pillar/airbag? Did you remove the cover first? Or just tuck it along the side so it doesn't impede with airbag deployment?
Old Jul 28, 2017 | 04:44 PM
SaphGreyC63's Avatar
2012 C63 AMG Sedan
You could also mount it directly to the overhead lamp area of the car. Much shorter wiring and very clean.
Old Jul 28, 2017 | 05:59 PM
2013 C63 AMG Coupe
I've done that on past cars. I really don't like splicing into existing wires if I can help it. Sometimes the connection can get flaky from road vibrations and that can blow a fuse. Also, finicky car electronics.
Old Jul 28, 2017 | 06:35 PM
SuckaGDog's Avatar
C63 AMG Black Series
I took off that driver's side cover and didn't see a fuse box in there. (12' C63 BS Coupe) Must be tucked way in there where I couldn't see it. Mine is wired to the cigarette lighter.
Old Jul 28, 2017 | 07:20 PM
Top Answer: 1
Its right there but not all cars have it, depends on options apparently.
I just tucked my wire up along the seal on the doors side of the a pillar then across the top and across the headliner.
Old Jul 28, 2017 | 07:24 PM
Top Answer: 1
Just got home a took a pic!
Attached Thumbnails Radar detector install using dashboard fuse box?-img_6039.jpg
Old Jul 28, 2017 | 11:10 PM
Amr_c63's Avatar
14 polar white E550
is that a switched 12v? Iv been trying to hardwire my v1 since I got the car and have had no luck with dome light wires in my 12 coupe.
Old Jul 29, 2017 | 11:31 AM
kickinrocks's Avatar
2013 C63 P31, V5 tune
Side note question. Any ideas on good mounting locations for an escort radar detector? Right now I have it windsheild mounted right next to the rear view mirror wired into the rear view. Apparently they offer rear view or blend mounts for every brand but MB lol.
Old Jul 29, 2017 | 02:26 PM
Top Answer: 1
That one is live with the key off to run a dashcam, but I think most of the other locations were switched if I remember correctly.
Old Jul 29, 2017 | 07:30 PM
Amr_c63's Avatar
14 polar white E550
ahh ok nvm then in that , can someone confirm what wire in the overhead panel is switched 12v that will shut off when the cars electronics go to sleep ? Or is everyone running it to the trunk fuse panel . Iv seen people wire them uptop but I don't want to have to switch my radar off manually everytime!
Old Jul 31, 2017 | 01:24 PM
2012 C63 AMG Sedan
Mine is wired up top. Turns on when car is on, turns off when its off automagically
Old Jul 31, 2017 | 01:51 PM
Amr_c63's Avatar
14 polar white E550
care to share what wires where tapped into , I have a 12 coupe if that changes anything ?
Old Aug 10, 2017 | 12:40 PM
Ludedude's Avatar
2014 C63 Coupe
Which wires did you tap?
Old Aug 10, 2017 | 05:45 PM
2012 C63 AMG Sedan
https://mbworld.org/forums/c63-amg-w...tectors-2.html
Read that thread.
Old Aug 10, 2017 | 05:58 PM
Amr_c63's Avatar
14 polar white E550
I have been through that thread and tapped into the same exact wires with no luck, my v1 turns on when i unlock my car and then never turns off even with the ignition off . its odd
Old Aug 10, 2017 | 07:54 PM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
With apologies for a little OT excursion here, I pretty much quit using my once-great Escort Passport 9500 because all the cruise-control radar in the new cars was setting it off constantly. Has anyone found a detector that doesn't do that?
Old Jul 9, 2018 | 03:27 PM
2013 C63 AMG Coupe
Uniden R3 blocks that.
Also, as an update to this thread, I finally hard-wired my radar detector up to the 12V cig lighter.
Steps and photos:
https://mbworld.org/forums/c63-amg-w...40-photos.html
Old Dec 21, 2024 | 07:28 PM
Macoj's Avatar
2014 W204 C63
I just did a similar install, was lucky too to have the dash fuse box. Fuse 123 is steering wheel vibration (comes with lane assist I guess).
I used an existing hole for the ground and directly plugged a blade connector in the fuse box (cable has an in-line fuse already). Power comes up with accessories.
I also placed the uniden remote under the steering column and added a power switch in case I want to keep the detector off.
The rest of the install is standard A-pillar cable routing.
