Ml63 w164 brake change
Hi guys attempting this tomorrow as i have changed brakes on every car ive owned since i was 16 including a few Europeans like an e46 m3 but never on a Mercedes and nothing as big as the brakes on the ml63 (15 inches i believe it is)
just wondering if anyone has some instructions or tips as ive searched and information is very little especially for the front brakes.
any help would be great
i saw a guy on youtube pushing his caliper pistons on his c63 with a screw driver instead of piston pusher/caliper tool, any thoughts on this?
I don't believe in replacing pads and not turning or replacing the rotors. That's kinda like installing new rotors without replacing pads, not very smart.
If the rotors have never been turned before, you should have enough left to turn them and still be in spec
I had all four corners changed about 2 months ago and my tech suggest they were OK and the new pads would bed in ok. He was right.
The thing to keep in mind and I saw this on my W124s is that if the shop doesn't cut them slowly they get a heat history set into them on the lathe and the minute you use the brakes hard enough to heat them up and release that set from overheating in the turning the rotor will warp.
fingers crossed when i get them into the workshop tomorrow there is enough meat on them
despite, "Ml63" comes with (390mm)..!
that may considering about the Rotor Hat height..?!?
*C63 Rotor Hat is (64.5mm) VS (55.1mm) Ml63 Rotor Hat..!!
-;ZAYED;-
https://mbworld.org/forums/gl-class-...kes-front.html
Here is one for the C63 style big AMG calipers, but I don't think these are the ones you have on that car?
