C63 AMG (W204) 2008 - 2015
Hardwiring from rear fuse box - dashcam
Old Aug 12, 2017 | 04:08 PM
hyp's Avatar
hyp
C63 Saloon (W204)
Hey.
I've just hardwired a dashcam from the fusebox in the boot (trunk) of my W204 saloon.
All is great, but it's not turning off when I switch of the ignition. I've run the cam from the rear power window fuse as I figured they only work when the ignition on, but the cam still seems to.
Am I being stupid here? Tell me if you need any more info and thanks in advance.
Old Aug 12, 2017 | 04:19 PM
bentz69's Avatar
'16 CLS63S
https://mbworld.org/forums/c63-amg-w...iring-diy.html
Old Aug 12, 2017 | 04:32 PM
hyp's Avatar
hyp
C63 Saloon (W204)
Thanks. My set-up is the same, except my runs from one of the 30 amp window fuses (on the rileftght in your pic). I'll give the cigarette lighter fuse a try in the morning - will the power to that one be killed when the ignition is off though?
Old Aug 12, 2017 | 04:34 PM
bentz69's Avatar
'16 CLS63S
yes. cigarette lighter only has power when the ignition is on.
keyless go ALWAYS has power
Old Aug 12, 2017 | 04:39 PM
hyp's Avatar
hyp
C63 Saloon (W204)
No keyless go for me anyway
Will switch the fuses tomorrow and let you know how it goes.
Cheers.
Old Aug 12, 2017 | 04:44 PM
bentz69's Avatar
'16 CLS63S
Cheers.
if you need a constant power source just use a multimeter to find one.
if your unfamiliar with them, follow these easy steps
turn the car off
remove a fuse
stick the positive end of the meter into the fuse slot
find a grounding source for the negative end of the meter
if the meter reads 12+ volts then you found your source
but that aside, sounds like you needed a switched 12v source which would be the cigarette lighter fuse. good luck
Old Aug 13, 2017 | 05:29 PM
hyp's Avatar
hyp
C63 Saloon (W204)
Switched over to the cigarette lighter fuse and all is working a treat. Potentially some sort of relay on the power window circuit? Who knows...
Thanks again for the help.
Old Jun 30, 2018 | 09:53 AM
alfster1's Avatar
2014 ML350 4MATIC
Hard Wire connection tapped to Fuse 151. A BlackVue PowerMagic Pro should be able to be hardwired similarly. (installed in ML350 - fuse box located under rear right passenger seat)
This is how I hard wired my dash cam. I have since replaced the ground connection with a larger wire washer.
