Tires of different dates, ok to use?
From Michelin website:
1- Keep five years in mind
After five years or more in use, your tires should be thoroughly inspected at least once per year by a professional.
2- Ten years is a maximum
If the tires haven't been replaced 10 years after their date of manufacture, as a precaution, Michelin recommends replacing them with new tires. Even if they appear to be in usable condition and have not worn down to the tread wear indicator.
This applies to spare tires as well.
http://www.michelinman.com/US/en/hel...ew-tires.html#
Your tire is almost 4 years old already. If you were putting it on a Honda, I'd worry about long-term problems. For rear tires on a C63, there is no such thing as long term. I think you're good to go!
Rubber compound stored properly is not going to degrade like it would if it was installed on a vehicle.
even a tire that is not mounted has a recommended shelf life. something to do with leaching of chemicals causing the tire to harden and degrade over time. something like that.
10 yr is rubbish. 6 on an every day tire and max 5 on a HP tire.
Second, if you mix new with old with different tread pattern you could get squrrley performance and some surprises particularly in the wet or on track. Side wall spring rates will be different as the cords in the old tire have been flexing in the rubber.
Why take the chance for $300? Buy them at least in pairs.
