C63 AMG (W204) 2008 - 2015
Intermittent Vibration At Highway Speeds?
Old Aug 22, 2017 | 04:49 PM
scallionrm's Avatar
2012 C63 AMG
Hi All! New to the forum and looking for some help. I did search around, and could not find anything relevant, so I'm reaching out.
So here's what's going on. I do get the vibration from time to time at slower speeds(50mph +), but at 70mph, it's pretty consistent. I'll be driving along and you will feel a vibration for about 2 seconds, then it goes away for 2 seconds, then comes back. It feels like it's coming from the seat and not the steering wheel, which would lead me to believe it's coming from the back. I also read in other threads that there's a carrier bearing(or something on those lines)that could cause a potential vibration, but I'd think it would be consistent.
Any thoughts? I'm kind of ruling out tire/wheel balance as the vibration could also be consistent and not on/off. Any help would be greatly appreciated!
Old Aug 22, 2017 | 05:59 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Check your control arm bushings, although I'd expect that to be more constant. Bad wheel bearing more likely IMO.
Also what side of the car is it coming from, or both.
Look at this: https://mbworld.org/forums/c63-amg-w...l-bearing.html
Old Aug 22, 2017 | 06:24 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
does it always happen on the same road or on all roads?
if it only happens on the same road, its the road reacting to the frequency of your tire/wheel/balance etc.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Aug 22, 2017 | 07:25 PM
BLKROKT's Avatar
I just re-read, sorry. NOT vibrating through the steering wheel. What you said about 'carrier bearing' makes sense. Check your driveshaft and rear diff?
Old Aug 22, 2017 | 08:24 PM
MTV10's Avatar
E55 AMG & C63 AMG
Check your control arms in the front. The dealership only, expensive ones....
Old Aug 22, 2017 | 08:26 PM
scallionrm's Avatar
2012 C63 AMG
It happens on all roads so I know it's not road related. I'll have to check the bearings/driveshaft and see if that uncovers anything. Thanks for the help all.
Old Aug 22, 2017 | 11:51 PM
Alex.currie44's Avatar
2009 SLK55 AMG. & 2022 GLA250 4Matic
One quick question. Does it change with changes in steering angle or when going around corners?
Old Aug 23, 2017 | 08:47 AM
Merc63's Avatar
C63 AMG
I'm getting a bit of a shake in the seat too, around 130kmh. I had all tires relaced and rims fixed/balanced etc. Very annoying.
Old Aug 23, 2017 | 08:59 AM
scallionrm's Avatar
2012 C63 AMG
Tough to say. Generally when I'm doing 70 around corners I'm not paying attention to any vibration I'll have to pay more attention next time I have the opportunity.
Old Oct 8, 2021 | 02:08 PM
Andres Morejon's Avatar
2005 E55 AMG
Has anyone figured out the source of the on and off vibration? Mine just won't go away
Old Oct 8, 2021 | 02:15 PM
Tires. 99% of the time vibrations are tire related.
If you have snows on separate rims put them on and see what happens.
If you can borrow a set from a friend do the swap and see what happens.
IF you move the front to the rear on both sides what happens.
I cannot tell you how many times over the last 35 yr and 13 cars vibes have been tire related.
The other thing is the drive shaft. Has it lost a balance weight.
Vibrations occur at different speeds it seems
Old Oct 11, 2021 | 05:17 AM
juggernaut1's Avatar
2010 Ford G6E Turbo / 2013 C63 Coupe - AMG Performance Pack
I agree with the above poster.
I felt a minor vibration through the car at highway speeds, wasn't constant per say, but periodically came and went, and I didn't feel it through the steering wheel. I never chased the problem but recently changed all tyres from the factory spec'd Continental 5P's to the well regarded Michelin PS4S's. Now she's smooth as silk at all speeds. Just as a FYI, I had previously changed the rears due to treadwear, which made no difference to the vibration.
On my other car I thought my front bearings had gone as there was a rumble coming from the front at suburban speeds. Changed all tyres due to treadwear and the rumble disappeared.
Old Oct 11, 2021 | 07:10 AM
Panzerbiscuit's Avatar
C63 AMG
On my daily I felt a weird sensation through the steering wheel, accompanied by a noise that sound very similar to bad wheel bearings. Needless to say I was annoyed considering I had just picked the damn thing up from a dealer who promises a 100 point mechanical check.
Jacked the car up and the wheel bearings seemed fine. Took it to a tyre place and the tyre fitter laughed at me. They were the same Pirelli Dragons that came on the car when it left the factory in 2011!. Chucked on a set of Yoko's and now it's smooth and quite.
Old Jul 26, 2022 | 02:55 PM
Kaisolin's Avatar
2017 c43 AMG Sedan
I have the same issue as the OP. Did you ever find a solution?
Old Jul 26, 2022 | 03:05 PM
Did you read the post above yours by chance?
99% of the time a vibration coming through the steering wheel at speed will be tires.
Old Jul 26, 2022 | 03:26 PM
Kaisolin's Avatar
2017 c43 AMG Sedan
Yeah I replaced my tires and had my wheels checked. Still got the issue =(
I'll take it into the mechanic tomorrow and if they can work it out I'll reply with the fix for me.
Old Jul 26, 2022 | 04:13 PM
2005 E55 AMG
My issue was my whes, one was cracking and after replacing them all no vibrations. Although MAYBE it was because an issue with lug bolts. Mercedes use conical (I think) I'd make sure you use the right bolts and maybe swap wheels with someone just to see what happens if possible
Old Jul 27, 2022 | 03:05 AM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
Mersedes use ball face lug nuts.
Old Dec 21, 2023 | 11:26 AM
tonytag25's Avatar
2012, Mercedes GLK 350
2012 GLK 350 rear end vibration while accelerating at high speeds
What was the fix for this?
Old Dec 21, 2023 | 11:27 AM
Kaisolin's Avatar
2017 c43 AMG Sedan
Replaced my continental tires
Old Dec 21, 2023 | 02:10 PM
tonytag25's Avatar
The fix for this was the tires?
Old Dec 21, 2023 | 02:39 PM
Kaisolin's Avatar
2017 c43 AMG Sedan
That's how I fixed my issue for the same problem he described
