C63 AMG (W204) 2008 - 2015
Any other things to check out/replace with headers install?
Old Aug 29, 2017 | 09:37 AM
NotABaller's Avatar
2012 C63, 2014 E550
Car is on hoist at EC Canada now and what other things are efficient/convenient to get looked at or replaced? I know my spark plugs are due but not sure if it makes sense to do now.
Old Aug 29, 2017 | 09:44 AM
SuckaGDog's Avatar
C63 AMG Black Series
Check out the motor mounts.
Old Aug 29, 2017 | 02:22 PM
NotABaller's Avatar
2012 C63, 2014 E550
Thanks!!
Old Aug 29, 2017 | 02:27 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Might as well replace all O2 sensors now, because the headers will blow out the old ones quickly
Old Aug 29, 2017 | 02:30 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
I wonder why is that. The primary should see the same exhaust fumes. the secondary's might see more being catless. always wondered why header cars blow through o2s
Old Aug 29, 2017 | 03:26 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
check for oil leaks. beyond that enjoy your headers!
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Aug 30, 2017 | 03:44 AM
Celicasaur's Avatar
W212 - E63 AMG
x2
I'd like to know the rationale to this also.
Old Aug 30, 2017 | 09:24 AM
kevy3's Avatar
2015 E63S, 2018 E63 EDITION 1, 2000 CIVIC SI EM1
Check the motor mounts, my passenger side had oil inside . getting fixed as we speak
Old Aug 30, 2017 | 09:46 AM
NotABaller's Avatar
2012 C63, 2014 E550
Thanks guys!
Old Jun 30, 2018 | 07:11 AM
ShaneN.'s Avatar
2018 e63s edition 1
How does one tell if a motor mount should be replaced? Or should I just go ahead and do them anwyays at 38k miles while the headers are getting done ?
Old Jun 30, 2018 | 07:22 AM
Vladds's Avatar
2010 C63 2019 GLA45
Jack the car, take the middle shield off. Try to put your fingers between the roll bar and the oil pan. I wear XL gloves and my fingers didn't fit, the mounts were compressed as compared to the new ones 1/2"+.
After mount change, obviously they fit with 1/4" clearance or so.
Old Jul 1, 2018 | 05:04 AM
ShaneN.'s Avatar
2018 e63s edition 1
I guess in my case it comes down to what are the chances mine need replacing now or soon. My car just happens to be going in for headers but only has 38k miles and I notice no signs of needing to replace them. If they cost a lot in labor and it happens my car is already booked in for headers resulting in it being an easier install, than I might go ahead and do them. But I'd prefer to wait unless it's really going to save by already have the cars in for headers - or if it's something that's going to be needing to be addressed soon anyways
Old Jul 1, 2018 | 08:27 AM
Vladds's Avatar
2010 C63 2019 GLA45
Determine if this is something that's going to be needing to be addressed soon anyways, using the method above.
Mileage is not the only factory, age and number of launches are equally big factors too.
Old Jul 1, 2018 | 08:43 AM
BLKROKT's Avatar
My car gets abused - hundreds of 1/4 mile runs and hours of track time - and my mounts looked fine at 34k miles. There is no rhyme or reason why some fail and others do not. It’s chance.
Old Jul 24, 2018 | 11:20 PM
ShaneN.'s Avatar
2018 e63s edition 1
Sorry for bumping this thread again but would the stock manifolds or headers (if you have them) actually need to come off to get at the motor mounts? I'm just trying to judge how much work there is to doing the motor mounts before I decide if I pick them up tomorrow with my new manifold gaskets, if my car doens't really need motor mounts yet.
Old Jul 24, 2018 | 11:36 PM
chrisridebike8's Avatar
'10 C63
if you replace the mounts, I would get the East Coast Euro mounts. Those look amazing.
Old Jul 25, 2018 | 12:00 AM
BLKROKT's Avatar
^ they are amazing
Old Jul 25, 2018 | 03:50 PM
blackbenzz's Avatar
haters crazy
Here is a DIY of engine mount install. It is a little harder to do if longtube headers are already on the car. But they don't need to be removed. Easy way to tell if the mounts are bad is look up from underneath with the underpanel removed and press on the rubber portion on the bottom of the engine mount. If it is soft and gooey then it should be replaced.
https://mbworld.org/forums/c63-amg-w204/699481-diy-w204-c63-engine-mount-install-east-coast-euro.html
Old Jul 26, 2018 | 05:45 AM
ShaneN.'s Avatar
2018 e63s edition 1
^ they are amazing
You're running them now and are happy? Any improvement over OEM seems like a good idea, as long as they aren't a ton more than the stock ones. The dealership here in Canada quoted me just shy of 600 for two motor mounts.
