C63 leaking bed plate seal
![](https://cimg3.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x360/1_0_8_4_10845392_thumb_a77e0e3f78785e2aea873485137489da62d56795.jpg)
![](https://cimg4.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x360/1_0_8_4_10845388_thumb_e29ebf0c70397b34225a55db4ac4d0f6d92d82b0.jpg)
![](https://cimg5.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x360/1_0_8_4_10845393_thumb_897b42bd6749767be96b878eb399cacb6725d51e.jpg)
![](https://cimg7.ibsrv.net/gimg/www.mbworld.org-vbulletin/640x360/1_0_8_4_10845389_thumb_7eb18f8e9d2faccfeb609136020e069ff2cb7fd4.jpg)
Took my car to dealership other day they told me i had a huge leak in bed plate seal and would require taking engine out to replace this seal and they want $8000 for it.. any thoughts? i havent heard of anyone else having such a thing
Yazan Alsharif (10-06-2017)
SPONSOR
2007 Mercedes E63 AMG
it is A LOT of work to reseal that. mine was leaking as well as from the oil cooler o-ring and valve covers. not 8k though...go somewhere else, and fix other things while you're at it to save in repeat labor. according to https://mbworld.org/forums/c63-amg-w...ml#post5103018 the engine needs to be pulled out to reseal this pan, so they're probably quoting you an engine out procedure.
i would recommend replacing the oil cooler o-ring, reseal upper, mid, and lower pan gaskets, and replace the oil cooler line o-rings if you have some miles on your engine. mine all failed/leaked/broke/hardened at/by 115k
i had all above done, with head studs, and lifter buckets and spent 5,500 in parts and labor through a buddy's shop. you won't have to do as much as me, but they'll have to drop the subframe a few inches to get the pan out. my mechanic said it was easy and he didn't pull the engine.
PNW_E63_AMG (02-27-2024)
it is A LOT of work to reseal that. mine was leaking as well as from the oil cooler o-ring and valve covers. not 8k though...go somewhere else, and fix other things while you're at it to save in repeat labor. according to https://mbworld.org/forums/c63-amg-w...ml#post5103018 the engine needs to be pulled out to reseal this pan.
