Larger/Additional Transmission Cooling for C63
To improve cooling capacity of our MCTs, some of us have tried looking into VATH, as they seem to be the only aftermarket parts maker that offers a Trans Cooler for C63 ( for both PFL and FL).
After multiple emails, I finally received a reply from VATH with photos, dimensions, and mounting installations of their FL Trans Cooler (Part 204.500.V.007).
Please see attached PDF for more info. I will email again for specs (BTU/HR, at what PSI if any were these units tested, etc) as they did not provide them with this email. But after viewing the photo and PDF, I am kinda disappointed.
This appears to be an Additional trans cooler that will be installed in serial connection to the stock trans cooler, and carries a hefty ~$800 price tag before shipping, etc. Dimensions quoted for their FL Trans Cooler below: 13.7 x 9.8 x 2.3 inches. (likely this is with the mounting tabs on both sides)
What do you guys think? Vath mounting instructions places this on the passenger side/upper position, which will partially block the Power Steering Cooler (reports of possible Power Steering fluid overheating exist). Where else would you mount it to further optimize airflow? A nice aspect of the Vath unit is the 90 Degree connections, but I am sure we can find similar connections elsewhere.
I understand the Trans Fluid needs to be at a specific operating temperature in order for the Trans Fluid to do its job and for the Multi-Clutches to engage properly, etc, so how an Additional Trans Cooler will affect this, I'm not really sure - it may just require a longer period of driving time to reach that temperature, after which we then can drive more aggressively.
I have been looking at other brands which may work as well, or even better: (Hayden, B&M, Derale) and at a fraction of the cost. It seems Stacked Plate oil cooler designs are more efficient than the other Plate/Fin and Tube/Fin designs.
Do you guys have recommendations on other oil cooler Brands that may be better constructed and more efficient?
Below is a photo of the Hayden Heavy Duty Units - altho they are not Stacked Plate design, they seem very robust, carry a 2 year warranty, and are only ~$100-130, not including connectors:
An additional trans cooler could perhaps also fit into that driver's side wheel arch, we may just have to move the Air Pump and Horns a bit, and cut out the stock grill to accommodate airflow.
The other option is what Weistec did with JRCART's BS - the dual fan cooler in the rear can either be for the trans, or for the diff. . . interesting:
http://www.*********.com/showthread....3-Black-Series
On one side of the hose it has hydraulic fittings that seem to be machine crimped and good for 200 PSI, on the other it has hose worm clamps that are good for 100 PSI. Now the 100 PSI has a lot of fineprint.
One being that a worm clamp loosens with heat. A spring clamp remains tight with heat, but does not go anywhere near 100 PSI.
In other words, there can be a possibility if what circulates in there is at 150 PSI and 230F, that it may spit the hose.
I researched this when I started to mess around with oil radiators.
The dangers are two fold:
at 150 PSI, you'll drain the transmission in less than a minute and you don't have a transmission oil pressue gauge in the dash, nor is there a low pressure light
if you're at the track and the oil goes on top of the red hot converters, there can be an oil fire.
I have not looked yet at the factory hoses, but I wouldn't be surprised if they're all hydraulic fittings, machine crimped.
I got one of these for the time being and having it installed as we speak ( given there is enough space). Also going to track this weekend, so can report back.
Another option is connecting a larger trans cooler to the Weistec Trans Pan, have it installed under trunk/spare tire region, and have a single or dual fan cooling this additional cooler.
This mounting option will avoid any interference with airflow in the front grills.
If anyone knows how to enable Trans Temp readout in the gauge cluster via perhaps MB Star Diagnostic, etc, please let us know.
Torque Pro Trans Temp
