C63 AMG (W204) 2008 - 2015
Burn smell/rotten egg smell
Old Nov 20, 2017 | 11:08 PM
Rick X Joaquim's Avatar
C63
i have experiencing some burn smell or maybe rotten egg smell whenever i stomp on the gas on high revs. The smell almost comes instanly but i could never detect it when im out of the car, even right after driving it hard.
i dont see smoke and no smell at normal driving.
anyone experiencing something like this?
i read it could be the cat but im not sure
Old Nov 20, 2017 | 11:53 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Catalytic converters going out.
Old Nov 21, 2017 | 12:06 AM
bhamg's Avatar
C63 AMG
Just in case they are on the way out you have an 8/80k warranty on them so get the efficiency tested.
Old Nov 21, 2017 | 07:16 AM
Vladds's Avatar
2010 C63 2019 GLA45
Start by checking how tight the intake manifold bolts are.
Old Nov 21, 2017 | 09:48 AM
C63
ok i will check it out.
but can you tell me what the tightness has to do with it?
Old Nov 21, 2017 | 11:38 AM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
i've honestly never smelt rotten eggs with any catalytic converter...even ones that were going bad or have melted.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Nov 21, 2017 | 12:15 PM
Vladds's Avatar
2010 C63 2019 GLA45
Several people, including me found the head bolts for the intake manifold to be loose. With those loose, unmetered air gets drawn in and due to improper AFR, you can get rotten egg smell from the converters.
You need to know the tightening torque for these aluminum bolts, so that you don't break them.
My factory bolts had an amount of elongation which was smaller than what it should be if they had been tightened properly. To me, this means that the techs (some of them), don't tighten properly on the line.
Old Nov 22, 2017 | 02:19 AM
G_Money's Avatar
That's what the smell like when they are going bad on the M113K. Just going off my previous AMG experience
Old Feb 4, 2019 | 06:20 PM
Steves40th's Avatar
GLK 350
Oops wrong thread
Old Feb 4, 2019 | 06:50 PM
BalanBro's Avatar
2012 C63 P31 Sedan
Do you have a secondary cat delete? Mine and several others smell like that when you're only running the primary cats. No smell when both were on.
Old May 5, 2019 | 05:51 PM
Bonesxxx's Avatar
2016 GTs, 2014 C63 AMG and 2014 C350 Sport (wife's car, she thinks it's an AMG - shhhhhh)
Bumping this up because I have the same thing. It never happens on the rare occasion I am in "C" mode. But whenever I use S+ or M, I get that rotten egg smell. It's worse outside the car than in.
I just had my 30,000 mile service. This may be a stupid question but don't they check the intake bolts during their 5,000 point inspection? - lol
Old May 5, 2019 | 06:44 PM
Bonesxxx's Avatar
Anyone happen to know the proper torque for these puppies? I saw 18 lbFt on another forum but it wasn't for a C63 so....
Old May 6, 2019 | 01:54 PM
Mort's Avatar
The Intake Manifold torque procedure is a three stage process. The bolts are aluminum, torque to yield and cannot be re-torqued. If you check them and they are loose you should replace them all. You will need the torque sequence as well.
Stage one: torque to 10Nm
Stage two: turn 90*
Stage three: turn 10*
File Type: pdf
File Type: pdf
Old May 6, 2019 | 01:59 PM
Bonesxxx's Avatar
Stage two: turn 90*
Wow that was above and beyond. Thanks Mort!!!
