C63 AMG (W204) 2008 - 2015
Having trouble hardwiring V1
Old Jan 11, 2018 | 08:53 AM
Amr_c63's Avatar
14 polar white E550
Cool Having trouble hardwiring V1
So after many threads iv skimmed over I cant seem to get my V1 to power up via hardwiring to trunk fuse panel , the car is a 12 coupe and the wires have been run from the front dome light area to the trunk 12v cig fuse spot using a add a line tap. The wires used are brand new and have no breaks or damages. I know the cigarette lighter fuse works because if I plug in the radar directly in the socket it works , I'm stumped as iv tried everything .... also my ground is mounted directly into the main ground point by the fuse panel in the trunk so a ground should not be an issue . Does anyone have any other ideas Iv done this on my previous cars with no issues ( bmw and audi ) .
Old Jan 11, 2018 | 11:17 AM
bentz69's Avatar
'16 CLS63S
If your using a tap, does the cigarette lighter work when the tap is plugged into the panel?
Try the keyless go fuse for troubleshooting to see if it works. But u don't want to use that fuse slot permanently
Old Jan 11, 2018 | 11:27 AM
Amr_c63's Avatar
14 polar white E550
YES the cigarette lighter does still work while its plugged in.. its odd would the gauge of wire maybe be an issue its standard 8g/6g wire which I'm assuming plenty enough for it . I don't have keyless go on my car unfortunately . Is there another location I could try on the panel that is 12v switched?
Old Jan 11, 2018 | 03:43 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Why would you run a wire to the trunk. There are only like 84 threads about this. Just splice into the dome light. The existing fuse can handle the minimal extra load. It takes about 10min. Mine has been hooked up this way for 4yrs without any issue.
Old Jan 11, 2018 | 06:07 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
https://mbworld.org/forums/c63-amg-w...-detector.html
Old Jan 11, 2018 | 07:12 PM
BLKROKT's Avatar
Precisely. Zero need to make it any harder than that.
Old Jan 11, 2018 | 08:42 PM
Amr_c63's Avatar
14 polar white E550
This is not a 12v switched on and off location I tried this and the radar stays on for me and turns on when I unlock the car . I want it switched on and off .
Old Jan 11, 2018 | 09:24 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
I haven't put it in my C63 yet, but the one in my E55 i wired to the cigarette lighter.
Old Jan 11, 2018 | 09:32 PM
BLKROKT's Avatar
Yes it turns on when you unlock the car. It also times out just like the lights and shuts off automatically 10sec after locking. It is switched on a delay.
Old Jan 11, 2018 | 09:43 PM
Amr_c63's Avatar
14 polar white E550
will the radar shut off even if I don’t lock the car ?
Old Jan 11, 2018 | 10:22 PM
BLKROKT's Avatar
Yeah it times out eventually. Might be 10min. It’s on the same delay as the auto shut off of the interior lights if you leave the door open with the car off.
Old Jan 11, 2018 | 10:34 PM
Amr_c63's Avatar
14 polar white E550
i see alright well that’s what I’ll end up doing then , I didn’t want to leave it wired there just Incase it doesn’t shut off and drains the batt.
Old Jan 11, 2018 | 10:37 PM
chrisridebike8's Avatar
'10 C63
I ran cables to the trunk. I prefer not to tap into wires unless I can solder it. I had a tap that eventually cut the wire in half. It's reversible and easy to use a fuse tap. make sure you are using an RJ11 cable. some phone cables won't work. did you try to use the standard pigtail provided cable provided by V1? I would just bring the V1 to the trunk itself (hardwire box to the V1 unit) and see if it powers up. If not, then I'm not sure what it could be, but if the stock V1 cable works, then you have eliminated the problem. I doubt it's the fuse tap (maybe check the fuses you are using?).
Old Jan 11, 2018 | 11:06 PM
skratch77's Avatar
2005 E55
I need a radar doctor but surprisingly I've only been pulled over in my Honda crv a few times and never in the 63 lol
Old Jan 11, 2018 | 11:37 PM
SuckaGDog's Avatar
C63 AMG Black Series
You’re gonna have to tap into the cig lighter wiring in the center console. That’s what I did and it switches on and off with the ignition. No delay with the interior lighting, that’s silly. I can only imagine how annoying that is when you open and close the car door when the engine isn’t running.
Old Jan 12, 2018 | 03:38 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
+1. Not sure if G Money means the cig outlet or the cig wires, but I have mine plugged into the outlet in the glove box. Turns on and off with the ignition, and no wire splicing.
Old Jan 12, 2018 | 03:56 PM
G_Money's Avatar
I tucked the wire in the headliner, behind the A pillar, then down behind the glove box and spliced directly into the cigarette lighter wires. I cant stand having wires hanging!
Old Jan 12, 2018 | 07:46 PM
I did the same, except I went into the glove box through the iPod integration kit hole on the side behind the panel, and then plugged into the outlet inside the glove box. No visible wires (hanging or otherwise), no splicing/tapping.
Old Jan 13, 2018 | 07:16 AM
Amr_c63's Avatar
14 polar white E550
Red face
I'm using a pigtail I bought from a company called ( Mirror tap ) which who iv used in the previous cars with no issue .. the cigg socket definitely has power and I'm directly going to the grounding point in the truck right next to the fuse panel.
I don't know how I would run the wire without them being exposed. Maybe run it down the A piller then under the passenger or drivers side kick panels ?
Unfortunately FL cars do not have a socket in the glove box
Old Jan 13, 2018 | 07:15 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Do the FL coupes not have the fusebox on the end of the drivers side of the dash, I just went across the headliner to there, super easy fusetap and done in my 13.
https://mbworld.org/forums/c63-amg-w...ml#post7223838
Old Jan 13, 2018 | 08:45 PM
m3driver's Avatar
09 C63, 04 CTS-V (just sold), 06 325, 15 500e, 96 NPR, 05 C172
I use this
http://www.valentine1.com/savvy/
and run the wire up the "a" pillar. You can tuck the "box" under the kick panel.
And you can add a BT transmitter and use the pretty decent app to get more info than the stock V1 display.
https://store.valentine1.com/store/closeup_20232.asp
yeah it's pricier than splicing into the wiring harness but hey it is a C63.
Old Jan 14, 2018 | 09:57 PM
Ludedude's Avatar
2014 C63 Coupe
my FL car does not have that fuse box.
Old Jan 15, 2018 | 08:30 AM
Mort's Avatar
My FL does not have the fuse-box at the end of the driver's side dash either.
Old Jan 18, 2018 | 03:56 AM
ShaneN.'s Avatar
2018 e63s edition 1
This seemed like the easiest route but I don' thave a cig outlet in my glove box, must be a Canadian car thing?
