ESS m156 supercharger install thread
I saw someone saying they can have ESS send their tune to work with HP Tuner, I want to know if that is true and will ESS do it. I believe it will be the best way of going about this. Get the vendor tune then drive to a tuner and dyno tune it. If it sound confusing because I am confused and not sure what are the tuning options for Mercedes. Coming from Honda world, tuning is a lot easier and less stress.
Perhaps later on I will look at seeing if they can setup a remote tuning session to dial it in and find some missing power, but for now, the ESS tune works great.
I have Row airboxes with AFE filters and Agency Power headers.
Sounds like that is the most effective way to go. What kind of mail method did you sent to them? Do they need the return postage paid? How long does it take to ship and wait for them to mail it back?
I used expressed registered and insured so I could track it right to the source. I can't recall but I believe they match your shipping method. Return was roughly 2 weeks I believe.
). AFRs stay consistent. Doesn't seem to run water temp hotter with the kit, My transmission (MCT) was fine at the track, no heat induced limp mode) but I have a 44O kit installed and the Weistec extra capacity trans pan. Stock Tranny is hanging in there. Installed a wavetrac LSD and the finned rear diff case. Car has a Wiestec catch can that during the summer stays fairly empty but during colder months collects a lot of goo. I would highly recommend a catch can. on a C63 (wish the Weistec one you could check the level without unscrewing the bottom of the can) I am also running a Gates HD belt, I had a RPM on there and ended up snapping off the routing pulley that comes with the ESS kit - they sent another one right away. - and also spun a stock pulley.. The RPM belts need an adjustable tensioner or one that is set lighter than normal to make up for the lack of belt stretch. The stock c63 was fast (mine was a PP car to start) , but this thing is plain ridiculous
you will not be able to receive the performance you expect from any "shelf tune" or any blanket tuner who doesn't literally spent hours building your tune from scratch. also, those tuners that offer "custom" tunes which they ask you to rent out a dyno. that isn't a custom tune...not even close. laughable literally a joke if you ask me. those boys have been taking you all for a ride for years.
Are Bosch 0280158117 the injectors that came with the kit? If not do you remember the part number?
I'm not quite clear on where to pick up power from for the coolant pump. It looks like it should pickup power from a location just before the green relay in the front fuse box.
Should the wire running to the pump be grounded in two places or just one?
