Car is cutting out at full throttle
im experiencing throttle cut out at full throttle. Im not sure if is the traction kicking in or what. I didn’t notice the exclamation on. The weather is around 8 celciius and im using michelin pilot super sport 4. The car would literally cuts off and back again making it fell jerky.
can the weather cause this?
I have a felling that is not the the TC . I have experienced TC kicking, and it is more like a full cut off and smother. What im experiencing now is way jerky. The throttle is like on off switch. This is stock tune.
If it's not the TC then it sounds like the ECU cutting fuel and/or pulling timing to protect the motor; it could be related to high knock or misfire. (If you have an ODB2 scan tool, there is a good chance you have a pending code you can retrieve which might shed more light as to what happened.)
Has anything with the car changed recently which might correlate with the behavior of the motor, such as ECU flash, were the air filters cleaned or replaced, or was there any condition where they might have become significantly more dirty at a faster rate (really depends on your location, but maybe sand from a beach or desert or carbon if your area was recently hit by a fire ... I know sounds kinda strange, that probably not applicable to most people, I live in CA and if one of our fires happens to be near where I live my air filters are completely black afterwards.)
Thanks for the reply.
i hate to blame on tunes, but i did have a few flashes back and forth. I noticed this in one of the tunes and i thought the problem was the custom i got. So i flashed back the stock tune thinking that it will be fix the issue. Unfortunately is getting the same thing cutting off throttle.
It Is been confirmed, it is not the TC kicking off.
it happens regardless of tune. But im pissed as this happened right after i loaded a new tune from the manufacturer.
if is indeed a corrupted ecu that is causing the issue, what can it be done?
(The AMG ECUs are a bit of a black box, I also have an Evo which has a lot more open software available for self tuning and hot discussions about topics so that's where these types of issues tend to come up, ie "I flashed a tune now then X happened." In almost call cases I recall its never been the ECU or tune.)
I think it can be pretty hard to test out a new ECU without getting Mercedes involved simply because of the lack of tech that we have available; any ECU that you get will be coded to the car that it came from so you can't just swap them in and out. At minimum the car will have an immobilizer which will prevent it from starting (and with it being Mercedes I'm sure there are probably other 'safeties' in place to prevent doing this.) On the Evo for instance one can very easily pick up a used ECU on ebay, either disable to immobilizer or re-code it to match their immobilizers code and you're good to go.
In the case that the ECU was damaged, I would expect the standard behavior for it to be that it just doesn't work at all, car doesn't turn on. In your case it would be very selective, as everything seems to be fine 99% of the time except for WOT and high engine load, from a damaged hardware perspective this seems hard to explain.
If you're set on testing the ECU (I feel it could be useful just hard to accomplish quickly and inexpensively) I think you might have two options:
1. Take it to Mercedes and have them flash it with a factory image
* they probably won't want to do this right off the bat, they'll want to diagnose the issue and probably as a last resort flash the ECU (you should also probably tell them that you had it flashes because I know they have the ability to only overwrite parts of the ECU, its not an all or nothing process) So you might want to to do a full flash to whatever degree that is possible.
2. Talk to a tuning shop like Kleemann, they have bench hardware that they use to verify their tunes on ECUs that customers send it. You might be able to send in your ECU and see if they're able to use their test hardware to validate it.
I hate to say this but indeed it happened after i flashed one of the tune. I wish it was something that would trow a code, so i can look it up. But there is no code. The car never did that even when I noticed there was tip in pinging in previous tune. I ask the manufacturer to dial in a more conservative timing. The next thing I noticed was cut off at high rpm though the car drove fine with added torque . The car drives fine with power, just cut off at high rpm. It seems more brutal with tunes over stock.
im heading to my mechanic to see what could remedy this.
2008 MB C350 4MATIC/2011 CL63 AMG/2014 C63 Coupe 507
I am experiencing this same issue; or similar. I recently got my m156 engine rebuilt, and suoercharged. No issues when i was NA. But now with a blower, when i go WOT, car hits a brick wall at around 6000 rpms and followed by fuel cut after. However if i perform like, 80% throttle, or less, it goes to redline..i tried different tunes, different injectors, no joy.
Has this issue been solved for you? If soo, what was the issue? Thank you.
Originally Posted by the_indian_kid;[url=tel:8907059
8907059[/url]]I am experiencing this same issue; or similar. I recently got my m156 engine rebuilt, and suoercharged. No issues when i was NA. But now with a blower, when i go WOT, car hits a brick wall at around 6000 rpms and followed by fuel cut after. However if i perform like, 80% throttle, or less, it goes to redline..i tried different tunes, different injectors, no joy.
Yeap, everyone took a peek at it. I had shops from instagram dial into my xentry via team viewer, did live runs. No joy. 😔 ny suspicion is the tcu/ valvebody, maybe the trans oil, or ecu needing tune in person. I even went the Syvecs route. Same damn issue. So clearly the ECU is okay.
2010 C63 P31 AMG
Just a quick check….but have you tried changing the actual pedal? Experienced this a few times a while back and it turned out to be pedal and incorrect readings. Worth a try. If not…hope you still get it resolved. Sometimes it’s the dumbest of things.
2012 C63 P31 Sedan
My theory is that a faulty accelerator position signal might be screwing up the torque management within the ECU, but it won't throw a code until it gets bad enough.
AMGSPY (01-23-2024)
2010 C63 P31 AMG
Thumbs up! We’ll hope OP gets this sorted. Yes my car would throw an ABS fault code on occasion and then nothing for a few other instances. Changed the pedal and it stopped. Seems like these pedals may have an issue after 70-80k miles.
AMGSPY (01-23-2024)
