Windows won't roll up also AgencyPower Exhaust Problems.
A few days ago I was driving I realized that my passenger window will roll down (single click and double click no problem) but when I try to double click for the automatic roll up. It won't roll up. It stops I had to manually hold it for it to roll all the way up and once its rolled all the way up it and i let go of the window button it will drop down like half an inch.
I took it to the dealership and they told me its the motor, they replaced the motor and it was fine for the first day but the next day same thing happened again. I took it back to the dealership and they told me they're not sure they have to look over all the wiring.
Anyone know what the issue could be?
Also I have agency power valve control exhaust. Anyone have issues of it closing on its own at higher gears and higher rpms? When I rev it too high past like 4/5 RPM it sounds quieter.
FWIW my car had the latest MB software update in Spring 2017, but still no dice.
- Close all the doors.
- Turn the smartkey to position 1 or 2 in the ignition lock.
- Pull the corresponding switch on the door control panel until the side window is completely closed.
- Hold the switch for an extra second.
if the side window opens again slightly:
- Immediately pull the corresponding switch on the door control panel until the side window is completely closed.
- Hold the switch for an additional second.
if the corresponding side window remains closed after the button is released, the side window has been reset correctly.
if this is not the case, repeat the steps above again.
I'll be cruising on the highway going around 60-65 and then suddenly when I go WOT, the car is super quiet. It's like the valves decided to close.
But
When I'm cruising normally and just give it a little bit of gas or half way to the floor it will scream.
