C63 AMG (W204) 2008 - 2015
P30 Break Rotors
Old Jun 14, 2018 | 10:11 PM
L83City's Avatar
C63 AMG W204
P30 Break Rotors
Hello MBWORLD!!
I have a Q about the brake rotors, i need to replace all four of them :\
i am a recent DIYer after being quoted thousands at the stealer ship
The Pads were already replaced previously. Brought all the tools following the HowTo guide here .. youtube etc.
Could i just move back the piston and take the caliper off without taking out the pads out??'
also when the Rotor off what do you scotch bright exactly at the wheel stub?
and are there any more resources for this process? , i know it's not surgery but i wanted to be sure
Old Jun 14, 2018 | 11:20 PM
capt_paul's Avatar
2013 C350 Coupe, 2005 C230K Kleemann Sedan, 2013 GLK350 4matic
Originally Posted by L83City
Hello MBWORLD!!
I have a Q about the break rotors, i need to replace all four of them :\
A car brake is a BRAKE, not BREAK
Old Jun 14, 2018 | 11:34 PM
Honro's Avatar
2011 C63 AMG P31
I would advise you to get new pads AND rotors. Your current pads have been "bedded in" with your old rotors. Re-using old pads on new rotors could cause uneven wear of the rotor & potentially even damage them or not make them work as well given the whole pad "face" is not meeting the whole surface of the rotor.
Old Jun 14, 2018 | 11:56 PM
L83City's Avatar
C63 AMG W204
i've driven less than 75 miles with the new pads... once in traffic, only heavy break once..,,, I will look into it though also
Do you know if these OEM rotors they do have a nice price
https://www.ebay.com/itm/Set-of-2-Br...ally+Aspirated
Old Jun 15, 2018 | 12:14 AM
cm60k's Avatar
Do you have (1.5-Rotor) or (2-piece Rotor)..?
-;ZAYED;-
Old Jun 15, 2018 | 01:04 AM
L83City's Avatar
C63 AMG W204
I’m not sure but the car has The performance package 2012 and the rotors have not been changed since . I ordered these to replace ( not sure if these are 2 piece )https://www.ebay.com/itm/Set-of-2-Br...ally+Aspirated
Old Jun 15, 2018 | 01:45 AM
cm60k's Avatar
Yeah these are (2-piece Rotors),,
even if you have (1.5 Rotors), these (2-piece Rotors) should fit perfectly..
-;ZAYED;-
Old Jun 15, 2018 | 03:13 AM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
For the next time, the regular one piece rotors work fine. You don't have to get the 2 piece. And yes, scotch brite the hub, but honestly, it's not necessary. And yes, you don't have to remove the pads.
Old Jun 15, 2018 | 04:24 AM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
It’s easier to hit the hub with a brass wire brush on a drill, then coat it with antiseize or ceramic paste (I sprayed mine with a light coat of high temp paint last time, not sure how that’s turned out yet)
And yes, you can just push the pistons in and hang the caliper without removing the pads. Just remember to go through the bedding process with the new rotors. It’ll be fine.
Old Jun 15, 2018 | 05:35 PM
L83City's Avatar
C63 AMG W204
Man thaNK YOU GUYS SO MUCH!!
what is the Bedding process? ( when all done pump the brakes until they are hard so the fluid fills the piston)?
Old Jun 15, 2018 | 06:58 PM
Mort's Avatar
Man thaNK YOU GUYS SO MUCH!! What is the Bedding process? ( when all done pump the brakes until they are hard so the fluid fills the piston)?
There are several suggested ways to bed brake pads depending on the source of the information and the type of use they will be subjected to. Don't be afraid to search.
https://www.google.com/search?q=bedd...ient=firefox-b
Old Oct 24, 2018 | 08:53 PM
Billmiranda's Avatar
2014 E63 S-AMG Wagon
What's crazy to me is that these rotors appear to be the same ones for my 2014 E63 AZMG-S 4matic wagon... which are 1200 or so apiece.
Looking at a number of aftermarket vendors,.. their aftermarket part numbers for the E63 and the C63 (and a number of other MB models) are the same. ie: Same circumference and thickness etc.
But... if you put in the E63 for this part number.. it (all the damned selection guides that sell Brembo) says they are not compatible. wth? I think I'll just get these from Ebay.
BTW,.. if you want to go even cheaper,.. this is allegedly compatible with the E55s (360mmx36mm etc).. which are also the same part number with a couple of aftermarket vendors.. but they (oem) are solid/not drilled/slotted... those are like $60 or so from places like Rock Auto.
-Bill
Old Oct 25, 2018 | 08:41 AM
BalanBro's Avatar
2012 C63 P31 Sedan
Yea, buying the Brembo branded version of the 2-piece rotor is far cheaper even though it's the exact same product. Since I'm going to keep my car around for a while, I bought my set from FCP Euro for around $850 for the pair with lifetime replacement.
I can also confirm that these 2 piece rotors fit just fine on the 2012 P31, which originally came with the 1.5 rotors.
Old Nov 4, 2018 | 01:05 AM
JustAVan's Avatar
C63 AMG, sold: E63 Wagon, R63
Sorry if I'm coming across as "thick in the head"...
So P/N 2194210212 rotors (referenced in the eBay link above) will fit a 2012 E63 AMG just fine?
How are they different than the OEM rotors that cost nearly twice as much??
Old Nov 4, 2018 | 06:45 AM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
So if you look up on EPC (realoem.com if you want to look yourself) the 2012 E63 and the 2012 C63 have the same front rotor part number. All year W204 C63 brake disks are interchangeable, so that means any W204 brake disks will fit your E63. The Brembo ones are the earlier P30 style and are actual 2 piece rotors that can be taken apart, unlike the newer 2011 and up design that cannot be taken apart. Brembo is one of the OEM manufacturers, so you are getting a as good quality part for significantly less. If you really want to spend less, you can also buy the base C63 non P30 rotors for about $150 each or less and they are a 1 piece design and a bit heavier as the center section is steel not aluminum.
Old Nov 5, 2018 | 02:28 PM
BalanBro's Avatar
2012 C63 P31 Sedan
My 2012 C63 w/P31 came with the same 2124210512 as the 2012 E63. I have since switched to the 2194210212 rotors up front and it fits perfect. I don't own an E63, but I can't imagine why it would not work.
The OEM 2-piece rotors, either the 2194210212 or the 2124210512 are made by Brembo for Mercedes. The Mercedes branded ones are expensive because they are still sold only as an MB product. In actuality, they should be cheaper as they use a cheaper co-cast process to mold an aluminum hub into an iron ring. Basically, MB is making tons of money on them, while the true 2-piece Brembo is a cheaper and arguably superior product.
Old Nov 5, 2018 | 07:28 PM
JustAVan's Avatar
This is excellent information, thank you so much.
May I have your thoughts on this train of thought: I am considering these 1-piece rotors (p/n Zimmerman 0004212012 ) as a replacement for my 2012 E63. I verified that other forum members have successfully used C63 1-piece rotors on the E63 (link to thread), albeit was a W211 AMG -- not a W212 AMG like I have. I do not track the car, so I am not too worried about any loss in heat dissipation / gain in weight.
Do you believe these 1-piece rotors should fit? I think they'd have to, given the cross-compatibility of the 2-piece rotors quoted in your previous post.
Old Nov 5, 2018 | 07:50 PM
Top Answer: 1
All the C63 rotors are interchangeable so the 1 piece, co cast or true 2 piece all fit, so those Zimmermans should be fine and certainly are the cheapest decent option if you are just daily driving.
Old Nov 5, 2018 | 08:10 PM
JustAVan's Avatar
I will order and post back with results. Hoping this will help others who do not want to pay $1k / side for OEM 2-piece rotors.
Old Nov 5, 2018 | 08:20 PM
Crya's Avatar
2009 C63 P30
yeah best to just get Brembos from FCP. Got mine from there to replace my worn P30 rotors. Nothing new here
Old Nov 15, 2018 | 08:29 AM
JustAVan's Avatar
As promised, here is the verdict: The C63 1-piece rotors (p/n Zimmerman 0004212012 ) worked perfectly as a replacement for my 2012 E63 floating 1.5-piece rotors.
​​​​For anyone nervous about doing the work themselves, it's a cakewalk if you have access to a lift. I went to a friend's shop and did the work myself (under his supervision, haha). The whole job took approximately an hour.
Zimmerman rotor (left) vs OEM rotor.
Old Nov 15, 2018 | 08:55 AM
SuckaGDog's Avatar
C63 AMG Black Series
As promised, here is the verdict: The C63 1-piece rotors (p/n Zimmerman 0004212012 ) worked perfectly as a replacement for my 2012 E63 2-piece rotors.
Just FYI, your original rotor isn’t a two piece. It’s a floating rotor AKA, a 1.5 rotor known here on the forums.
Old Nov 15, 2018 | 09:05 AM
JustAVan's Avatar
Thanks! I'll adjust that.
Old Nov 16, 2018 | 03:14 PM
I verified a lot of this through aftermarket sites like one of the sponsors/vendors here. Their brake rotors for about 2 dozen different models throughout the years are the same part number so,.. I really don't care what MB says in this case. If aftermarket companies are selling the same rotor kits for so many vehicles,.. then it shows me that the rotors from those cars will also fit my 2014 E63 wagon. I refuse to pay 1300 or so per rotor when I can get better (2 piece -vs- the 1 piece on my car) for half price.
Thanks to all who took the leap and verified a lot of this.
Old Nov 16, 2018 | 09:32 PM
AMG6.3's Avatar
C63
Buy solid one piece rotors from FCP Euro for $500 or less for all four. You don’t need two piece rotors if you want to save money and you won’t notice a difference on the street.
