C63 AMG (W204) 2008 - 2015
Got lucky guys...saved my engine!
Old Aug 5, 2018 | 05:05 PM
skratch77's Avatar
2005 E55
Long story short I was pushing this platform to the max staying na and running alot ot timing and great flow numbers. I think I was seeing 430-440gs/sec on my final setup.
The car was running strong and then one day I heard a really bad noise and days later was seeing blue smoke out the pass side exh.
Here is what my cylinder 2 looked like.
Old Aug 5, 2018 | 05:12 PM
skratch77's Avatar
2005 E55
I started taking everything apart and took all my mods off to get the car back to stock and see what the dealer said as I still have some warranty left.
I had 2 dealers tell me it's fine and compression is good and I figured they didnt scope it and did it myself. I saw this cylinder and it's the one that would misfire from time to time and thought the motor was f*ucked.
I took the manifold off and cleaned it as it was full of oil and that was my smoke issues and the car has been smoke free for a few months now.
I decided to run a few bottles of gunk cleaner in the gas and didnt bother with it until now as I was just waiting for the car to fail and literally driving it hard to get it to fail so I could rebuild or see what the warranty would cover.
fast forward now and decided to look at the cylinder and its fine now.it was carbon and not gouged like I thought it was.
it sucks because I sold my whole setup for 2200 bucks and I'm trying to buy it back off the kid as I type this.
Old Aug 5, 2018 | 07:28 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Wow, the cylinder looks great good luck buying all your mods back!
Old Aug 6, 2018 | 03:39 AM
Celicasaur's Avatar
W212 - E63 AMG
Does it still misfire? Blue smoke still?
Old Aug 6, 2018 | 09:10 AM
skratch77's Avatar
2005 E55
nothing been 3 weeks of hard driving too.my intake had about a half quart of oil in it and was the reason for the miss fries and blue smoke.
I'm going to run a few more bottles of carbon cleaner and take more pics of the cylinders
Old Aug 6, 2018 | 09:13 AM
Celicasaur's Avatar
W212 - E63 AMG
Interesting.
I had something sort of similar with my E55 a few years ago. The oil level sensor played up and told me I had nothing in there....I ended up adding too much and then had it drained out again. I remember smoke, but not misfires.
Old Aug 6, 2018 | 05:30 PM
MBNRG's Avatar
I take it you were not running a catch can, correct?
Good call on scoping yourself! Best of luck, and hope you get your mods back man
Old Aug 6, 2018 | 06:31 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
i drive hard pretty often. you need heat to burn off anything that builds up.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Aug 6, 2018 | 10:48 PM
knowbenz's Avatar
Benz
Curious what scope that is, images are pretty decent
Old Aug 6, 2018 | 11:02 PM
skratch77's Avatar
2005 E55
These cars definitely need a catch can.i still cant believe that my car was miss firing from oil in the intake manifold.
The scope is a China amazon cell phone scope.it was kinda shady as you have to go to a web site and download the software for it and side load it as the app is not in the playstore.
Old Aug 9, 2018 | 05:43 PM
jptaylor's Avatar
W213 E63S Wagon, W204 C63 P30(RIP), WK1 Grand Cherokee SRT8(RIP)
All things considered good catch though....I posted pics of the inside of my intake years ago on here showing how FULL of oil and sludge it was....but others post pics of spotless runners
Old Aug 11, 2018 | 10:41 AM
skratch77's Avatar
2005 E55
I ran another bottle of gumout and techron in the tank and it's looking alot bettter! After this tank of normal gas I will run bk44k fuel cleaner as they say it's the best out there.
Old Aug 11, 2018 | 11:06 AM
jptaylor's Avatar
Damn it Skratch, now I've got to go scope mine!!!!
which route are you taking to scope it, spark plug?
Old Aug 11, 2018 | 11:14 AM
skratch77's Avatar
2005 E55
yes I'm just going by cylinder 2 because it's the only one that pended a miss fire. I'm going to assume the other cylinders are getting cleaned also.
I was skeptical of the gas additives but the pictures are proof they work.
Old Aug 11, 2018 | 11:22 AM
jptaylor's Avatar
Thank you much...I'll post pics here when I scope mine this afternoon (changing plugs today anyway)
As for cleaning I have always used the seafoam method where you sip from the can with the brake booster vacuum hose until half the can is gone. Then you BURY the hose so that it chokes out the engine and a huge plug of Seafoam covers and coats the entire upper drivetrain(including most cylinders as intake valves should be partially open while it's choking out), pour whats left in the can in the tank. Let it sit as is for an hour or so then crank it up and beat the **** out of it for about 5min...it will smoke like a forest fire but the smoke is all the schmutz burning out. Whenever I've done this in the past and scoped after it has always been BEYOND amazing, I mean nearly spotless.
But I promise I'm currently Googling the products you referenced!!!!
Old Aug 11, 2018 | 04:26 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Very cool. Now I’m shopping for a scope too lol.
Old Aug 13, 2018 | 06:42 AM
Vladds's Avatar
2010 C63 2019 GLA45
Don't get super intense with the fuel additives because they're corrosive and can affect the fuel tank. Also the "additives" in the exhaust gases which are a result of the cleanings can fog the oxygen sensors, coat them and make them less responsive.
Some gum can travel to the injectors and make those less responsive too.
Old Aug 23, 2018 | 09:56 PM
skratch77's Avatar
2005 E55
Here is the final update after going through a tank of gas with bk44k in there.
I can freaking read the numbers on my cylinders and I scoped the valves through the fuel injector hole and they are super clean.
Old Aug 23, 2018 | 11:58 PM
J0HN_R1's Avatar
'19 4runner TRD / '12 C63 AMG
Wow...
That's impressive ! BG44k you say ?
Old Aug 24, 2018 | 12:04 AM
skratch77's Avatar
2005 E55
Originally Posted by J0HN_R1
That's impressive ! BK44k you say ?
It's called bg44k. I would get 2 can and run them back to back.
Old Aug 24, 2018 | 12:51 AM
Tomsti's Avatar
CLS55
It's hard to tell does the piston crown have detonation marks on it? What is that?
Old Aug 24, 2018 | 01:24 AM
Celicasaur's Avatar
W212 - E63 AMG
Impressive...
Old Aug 26, 2018 | 03:59 PM
skratch77's Avatar
2005 E55
I'm putting so much into this car lol...I'm doing thermal spacers and I wrapped the under intake manifold in thermal tape.
Old Aug 26, 2018 | 06:12 PM
BLKROKT's Avatar
Nice bro. I did those Sikky spacers when I did the 82mm TBs. But that tape is next level stuff. Don’t forget to do the lower air boxes too...
BTW, did you just follow the standard torque process for the IM TTY bolts? I have some weird codes I’m tracking down, and have a feeling that the IM bolts have loosened. I don’t think the torque process is sufficient with the spacer in there. Was considering replacing with studs.
Old Aug 26, 2018 | 06:42 PM
skratch77's Avatar
2005 E55
I just bolted back up but getting a whistle ping noise and got a bunch or random miss fires.
I also just changed all fuel injectors at the same time.
on the torque specs I'm just going as tight as I can by hand.
tearing it all apart now and putting my old injectors in as I was getting 50+ fuel trims on both banks and the car was stumbling.
