MAGNUSON Superchargers and belt slippage in peticular magnuson c63
Its supposed to be bolt on not pay extra for sledgehammer kit so its 8 ribs and supposed to stop the issue. But 2.5k for a pulley setup is dolars.
Anyone have any insight?
Never had the problem before magnuson.
Im sick of belts going it is supposed to be oem like kit and it is awesome dont get me wrong drivable, better than stock, power, cant fault it (touch woodf) but im slipping the belt you can see wear on the ribs of slippage too.
I need an 8 rib or the sledgehammer kit. No one else seems to have had a problem though.
I ight email magnuson
- Have you replaced the tensioner? If not, do so. If you have, is it a genuine (Gates) unit ... there are cheaper copies that flex badly.
- Have you checked the engine coolant pump bearings are still good? There will sometimes (usually) be evidence of coolant leaking, but I have experienced a GM pump that had very bad bearing but still sealed.
- Have you checked/replaced the idler pulleys? They are renown for premature failure and have caused belts to escape even without supercharging.
- You indicate the "pulleys are good". How did you check. The best (nearly only) way is with a laser alignment tool.
Also... Different belt brands can produce different results. The Magnuson-branded belt supplied with the kit is a purpose-built belt from Gates - it is a grade between "FleetRunner" & "Carbon Race".
I might do to a different shop. Get them to check alignment and why. These guys are seeming a bit hopeless if there fix is dont get up it ful l throttle and wait for a sledgehammer kit. Thats not correct way to fix it. Really ****ting me now.
Thanks for your response.
Wtf it cant be that hard. I was a mech we did correct work why cant someone else. They are good at the cars they do maybe just not mercs.
Of course, the best way is a SledgeHammer kit ... I have them ready to ship.
Im aus. How much will you sting me on a sledge hammer? And where are you? I dont wamt to up the boost yet or prob never i ususally drive a lot and have it tuned to a streetable and sweet spot and it still hauls ***.
