Phil1305 C63 Progress/Mod Thread
I'll attach a link if I can find oune.
While we are on the subject, we should touch on dimple ports. The argument is that it works on golf ***** because it creates a boundary layer of air and helps it move the ball faster and farther. In a port, we are looking to create a situation where fuel stays off the wall of the port. So the dimples would (in theory) help create this boundary layer of air that would keep the fuel off the wall and in suspense and atomized.
First off, more than likely you have an engine with modern fuel injection if your reading this. Modern fuel injectors do an excellent job of atomizing the fuel, especially with todays engines where injector location is engineered very carefully for optimized delivery. So, the only true advantage I see in dimple ports is if you’re playing discus with the cylinder head and want to see how much farther you can throw it. If there was any real basis for dimple ports, you’d be seeing it in high-performance factory engines and professional level race engines and that’s simply not the case.
Probably not of any interest to most of you, but at least next time you see those awesome pictures of CNC dimpled intake ports on websites, you can rest easy knowing that they don't help performance, especially if the whole port is dimpled!
https://cliosport.net/threads/does-d...ork-no.817453/
any dimple work for ports will need to end well before the bowl of the intake port. as far as dimpling anything beyond the head ports...pointless as it isn't in contention with needing to increase acceleration or to create a boundary layer. if dimpling did anything, you would see it on airplane wings and rudders as in the aviation industry, even 0.5% of fuel savings can equate to millions saved a year.
it will however gain power with the case inlet and throttle bodies though allowing alot more air to enter it easier.
You would not see it on airplanes. Because airplanes are more prone to skin friction drag because they are already designed with streamline in mind.
Golfballs are held back by pressure drag and that is where the pimples help.
Also my new aluminum 1.5 gallon meth tank came in as well. The other plastic 2.5 gallon just barely fit in the space I had in the spare tire well and wasn't gonna mount neatly enough for me. So I ordered this new one
Also, had my shop helper sorting through my stainless bolt stash to get the right length for me to continue getting everything assembled.
I also ordered everything for my titanium 3.5 inch intakes, hopefully it'll be here soon as I'm getting excited to get this thing going and retuned.
My mini vacuum block from damond motorsports also came in, this thing is really nice quality and great size but it's expensive at 50 bucks. I got it mounted and ran my hitemp air line and cover it in dei heat shrouding. This will serve for the vac/boost source for the meth controller, and also for a temporary mechanical boost gauge and in the future for a pressure transducer for standalone.
Lastly, the titanium showed up for my intakes. Waiting on filters and couplers still but plan is to get them made Easter weekend.
I made a bracket to hold my meth pump and solenoid for in the trunk.
Also, the intake tubes are mocked up and waiting to get welded up and finished.
Here's some of the titanium 3.5 inch intakes and the progress so far.
