C63 AMG (W204) 2008 - 2015
Phil1305 C63 Progress/Mod Thread
Old Nov 29, 2020 | 12:19 PM
  #176
Phil1305's Avatar
C63
Originally Posted by Jasonoff
This wasn't news to you was it? It's the major cause of failed head bolts.
I figured the water jacket was below the threads in the block, as in not sealing the threads well enough aloud water to reach the bolt head. Not that it goes straight into a water jacket first then the threads.
Old Nov 29, 2020 | 12:25 PM
  #177
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
That's why you see pitting because of the flow by. Did you do this with the coolant already drained? Sucking the coolant out of the threaded hole was such a pain.
Old Nov 29, 2020 | 12:38 PM
  #178
Phil1305's Avatar
C63
Lol, no I drained it. But the fist bolt is took out there was coolant to the top still, so I rigged up my mini shop vac with vacuum line to clean it out.
All in all it was easy job besides being really time consuming. The stud for the left head rear ward bottom most took a bit of persuasion as it hit the shielding. Also, the getting the cams to line back always takes the most time and was a pain in the ***. I even have the mb tech tools to do it, I was one tooth off a couple times so I had to reloosen them and fix it. It was decent job and one more thing towards bullet proofing the engine.
Old Nov 29, 2020 | 02:54 PM
  #179
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I used a mittyvac with a 16" length of 1/4" stainless hard tube attached to the hose. I didn't drain the block so it took a while.
How are the knees? Had to continuously remember to keep them bent for the 2nd job on a friends car.
Old Dec 4, 2020 | 05:08 AM
  #180
Phil1305's Avatar
C63
my knees weren't so bad it was my lower back. I cant hover over a lower car in my ripe old age of 34.
Old Dec 4, 2020 | 09:22 AM
  #181
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It goes downhill fast at 40...
Old Dec 4, 2020 | 01:30 PM
  #182
Phil1305's Avatar
C63
lol, I bet. Its already started past 30
Old Dec 4, 2020 | 01:33 PM
  #183
Phil1305's Avatar
C63
Idk if I posted this before but my oil came in for my oil change. A bit bummed because the oil in the car maybe has 500 miles on it. But after a little antifreeze spillage and redline assembly lube its best to change it etc.
Old Dec 9, 2020 | 09:36 PM
  #184
Phil1305's Avatar
C63
Made a little head way on relocating my power steering reservoir this morning. Its kind of a pain in the *** because of the direction the 3/4 nipple comes off the power steering pump. So I searched for a long time to find a 3/4 oil resistant/power steering hose with a 90 degree bend. I finally found one that works ok, its not perfect by my standards but itll do. I also made a bracket at work to mount the reservoir to the rad support.
Old Dec 10, 2020 | 06:37 AM
  #185
Phil1305's Avatar
C63
Also, forgot to show a little present that showed up yesterday. My used 82mm throttle bodies i got. They're all over ebay and salvage yards for cheap. If you have a blower car I'd definitely do these right away!
Stay tuned over my Christmas vacation getting my meth installed, throttle bodies and my diff mount installed.
Old Dec 10, 2020 | 11:59 AM
  #186
YYCStage3's Avatar
2012 C63 AMG P31, Stage 3 Weistec
Are those off an E55?
Old Dec 10, 2020 | 12:00 PM
  #187
Phil1305's Avatar
C63
should be anything 55/550 N/A
I paid less than 300 for the pair, and you can find them a little cheaper
Old Dec 10, 2020 | 12:42 PM
  #188
YYCStage3's Avatar
Sweet deal. Especially compared to $1,300 ea from Weistec.
Assuming they are direct bolt on, and no adapter plates or mods needed to the SC Y inlet?
Old Dec 10, 2020 | 12:54 PM
  #189
Phil1305's Avatar
C63
The mounting is supposedly off a little bit, so you just have to drill out the mounting holes a little bit.. i don't have on of my stock ones off yet to compare.
Old Dec 14, 2020 | 05:26 PM
  #190
Phil1305's Avatar
C63
So wanted to post the big scare I had the other day. After getting the car back together, I fired it up topped off antifreeze etc and also to make sure the tapping on the new lifters went away.
Well, I started the car and pulled out of my driveway and drove down my street. A car was a little close behind. After driving for about a mile or so a notice the car back off and a big plume of white smoke. Looked like an old Taurus with cracked heads lol.
I was driving real easy just to get some break in miles on it. Once I got home I checked over a few things, drained my catch can which about 4 ounces or so of water came out.
Long story short way more antifreeze got into the oil that I saw or noticed but not enough to milkshake it. And I was doing the start up and short test drive on that oil before I change it. I had like 16 quarts of mobil 1 10w30 that I changed it with just to do a good flush with before I put my schaeffer's in.
Good news is the oil was the problem with antifreeze in it and once changed it cleared it right up.
Also have some pics of the frame and meth tank mount.
Old Dec 14, 2020 | 06:47 PM
  #191
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
I know that pit-of-your-stomach first-drive problem feeling all too well well. Glad this one wasn’t a disaster.
Old Dec 14, 2020 | 08:55 PM
  #192
Phil1305's Avatar
C63
lol. Yea I was like wtf I spent way too much time doing these headstuds right what the hell happened. I also Said, **** this car you can sit until next year you peice of junk.
But yea after more investigation I figured it out. Also found out that in moderate Temps my tune is absolutely garbage as in undriveable with misses and very very bad driveability. It wasn't this bad in 30 degree weather but in 50s it sucks.
Old Dec 16, 2020 | 10:18 AM
  #193
KXC's Avatar
KXC
C63
Pardon me if you mentioned this but did you swap the head studs in and leave the head gaskets in place ?
Old Dec 16, 2020 | 10:35 AM
  #194
Phil1305's Avatar
C63
yes, you swap the headbolts out one at a time.
Old Dec 16, 2020 | 12:23 PM
  #195
HLG600's Avatar
2009 SL63 AMG
Glad to hear this was a crisis averted. It's incredible how much leniency is given to tuners when it comes to bad tunes. Hopefully Barry gets you sorted out.
On a separate note, that Shaeffer's 5W50 looks interesting. What was your reasoning to use it over the usual options?
Old Dec 16, 2020 | 01:38 PM
  #196
Phil1305's Avatar
C63
I never usually follow the crowd, and schaeffer's Supreme 9000 5w40 or 5w50 has lots of zinc and calcium which is good for flat tappets. The others are good but i look for better for my style driving etc.. i used to run motul 8100 but again look for the best option for me since im absolutely unforgiving on my car.
Old Dec 16, 2020 | 01:42 PM
  #197
thebug44's Avatar
2012 P31 C63
random question, I tried looking through your thread to find your wheel specs. can you give me those details and where you got your wheels from?
Old Dec 16, 2020 | 01:49 PM
  #198
Phil1305's Avatar
C63
for my welds? Drag wheels?
Old Dec 16, 2020 | 01:50 PM
  #199
thebug44's Avatar
2012 P31 C63
sorry, should have been more specific. yea the welds/drag wheels
Old Dec 16, 2020 | 01:58 PM
  #200
Phil1305's Avatar
C63
I bought them right from weld. Also they don't make our bolt pattern so I sent them to a company in California called Jason's wheel repair where the redrilled them to 5x112 and put in steel inserts. I also had them powder coated gloss clear so I dont have to polish them .
redrilling was cheap, iirc it was like 35 a wheel but shipping out there etc was rough. I think I had about 1600 total in both wheels for everything.
