C63 AMG (W204) 2008 - 2015
View Poll Results: What should I do?
Change the oil if it works fine, buy it
8
80.00%
Just run away
2
20.00%
Voters: 10. You may not vote on this poll
Transmission Oil for MCT Speedshift
Old Jan 3, 2019 | 12:40 AM
Hussein Bazzi's Avatar
C63 2013 w204
Guys question. A guy selling a C63 didn't do a transmission oil change since he got it and its a 2012 with 88,000 miles on it. I drove the car, it shifted great, quick and smooth, should I just do a tranny flush ASAP or run away? I know that in normal AT with a torque converter if the transmission oil hasn't been changed the oil becomes thick due to the heat and the tiny shards of metal that is due the wear and tear over time, if the transmission's oil is changed it starts to slip and basically needs a rebuild. Is it the same case with the MCT? I know that MCT has wet clutch packs, will changing the oil simply resolve it or should I run away even if it is shifting smooth and fast?
He did tell me that the car's transmission is slightly jerky when the car is still cold, but it goes away when it heats up. is that normal?
Old Jan 3, 2019 | 02:24 AM
c63_alex's Avatar
2012 C63 AMG - 2006 Mitsubishi Evo IX - 1979 Jeep CJ7
The MCT is a jerky transmission. If it shifts smooth I’d say it’s good
Old Jan 3, 2019 | 04:04 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
I mean if it's NEVER been serviced (every 40k miles is the major trans service), I'd just get that done and probably call it good to go. These transmissions are pretty stout.
Old Jan 3, 2019 | 10:52 AM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
Check out that old tired fluid, your transmission will thank you.
Old Jan 3, 2019 | 10:59 AM
Amr_c63's Avatar
14 polar white E550
I had mine changed at the dealer and the car didn't change one bit , my transmission does have an issue though as it slips on the lower gears with minimal throttle . Also I am getting shift "flare" which some don't know about its basically when the car shifts and wants to settle into that exact gear it tends to jump/fluctuate the rpm . Also this happens when the car gets warm when its cold it doesn't do it .
didn't mean to jack the thread but if its not acting funny just leave it alone .
Old Jan 3, 2019 | 03:42 PM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
Are you doing the same with your engine oil? If the engine isn't acting funny you just don't change the oil?
Old Jan 3, 2019 | 04:16 PM
Amr_c63's Avatar
14 polar white E550
The engine oil isn’t lifetime ? Omg...
Old Jan 3, 2019 | 06:35 PM
chrisridebike8's Avatar
'10 C63
neither is the trans fluid. It’s scheduled to be changed every 40k. This car has gone more than double that. Would you go 20k+ without changing your engine oil?
Old Jan 3, 2019 | 11:22 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
If you can’t afford a possible $10k transmission rebuild/replace bill, or you aren’t getting the car at a significant savings versus the market, run the other way. If he hasn’t done a trans fluid change, it’s likely he didn’t do much of anything including Services A and B maybe even oil at normal intervals. Plenty of good FL cars out there with perfect service history.
Old Jan 4, 2019 | 01:52 AM
Gazwould's Avatar
S204 C250 CDI Sport
If it's 7g since it's 2012 the interval is higher ,
5 years / 77, 500 miles or is it less for the C63 ?
Old Jan 4, 2019 | 02:06 AM
c63_alex's Avatar
2012 has the MCT not 7g
Old Jan 4, 2019 | 06:17 AM
hichamaziz's Avatar
cla
Subject
The mct is jerky transmission
Old Jan 4, 2019 | 06:32 AM
C63AMGeez's Avatar
W204 C63
If its jerky, I'd start off with a TCU reset first. That may resolve your jerk problem. Deciding to change the oil after 88k miles is a shot in the dark.
Old Jan 4, 2019 | 08:20 AM
The transmissions with the torque converter and MCT are both 7g Transmissions.
7g stands for 7 Gang. (7 speed).
