C63 noise on acceleration
I've attached a video it's a bit hard to hear but try to listen when I'm pressing on the gas. The sound is constant then when I got home I had a "check oil level at next refuel"
Weird cause I just got the oil change last night.. Anyways I'm not sure if the noise and oil light are correlated but I am more concerned about the noise.
Can someone chime in?
https://youtu.be/uWYKvemCdYM
Could be anything... but I'd check the obvious things first. A loose exhaust clamp was the culprit last time I had a mystery noise.
But, since it was just serviced for oil and gaskets and you are getting a low oil level alert the first obvious thing is to take it right back to the service shop for a top-off and look-see.
I want to thank you all for your assistance in chiming in. I am going to top up the oil. I can't see it missing more than a quart. If I am able to get a better video I will upload,
I have a Huawei p20 pro and when I listen to it on my phone I am able to hear it, but thats probably because I know what to listen to
The check engine oil at next refueling has not resurfaced! so that fixed one thing.
Now the noise is still present. It's more noticeable when you're on the highway because the exhaust noise doesn't drone it out and you're in a higher gear so the car is a quieter making it easier to hear. It definitely correlates with the acceleration pedal.
I've just ordered UPD Pulley and a serpentine belt..maybe that will be it?
Sounds like top end to me but that's what I thought the time it turned out to be a loose exhaust clamp... until I got out of the car and listened with the hood open I had no idea.
can a loose exhaust clamp make that noise under power?
I think you'll feel better (or worse) just knowing where the sound is coming from. Did it get any better when to topped off the oil? Seems to me it is likely related to your recent service visit.
It was a contingency before I bought the vehicle I wanted to make sure there were no leaks. I topped off the oil (1 quart) now and it's fine no more 'check oil at next refueling' alert.
I still have a faint acceleration noise, it's very faint even in person so I doubt a camera would be able to capture it.
But -- yes the noise was ONLY present after the repair. No CEL or anything. Car pulls strong.
Curious to know this is my first time owning a V8 AMG. At idle the car grumbles quite a bit eh? you can feel the vibrations from the grumble thats normal ya?
I also have a resonator delete which may be adding to that vibration a bit.
the only problem is the AMG exhaust is so damn loud lol! It eats up most of that noise and makes it hard to hear!
I noticed a noise from one of the heads so tracked the sound down to front of the head where the cam adjusters are.
Try this:
Run your ear down each side of the motor while its running and at running temp (90c water 100c oil) and listen for any sounds that aren't the clicking of the injectors.
Put a large screw driver to your ear and then touch it to parts of the motor to try narrow down any noises. Only had the noise on one side of the motor.
Might not be the same issue as me but sounds very similar. Is it like a clattering sound? Similar to what a Diesel engine would make? Its really faint in the cab but you can hear it at low rpm (1500-2000rpm) mainly while taking off from an intersection.
Try this:
My thoughts are CAM adjusters or solenoid since thats about all that's in that area.
For the time being here's my write up for the mechanic.
Vehicle: 2012 C63 AMG
Problem:
1. Rattling sound under acceleration
2. Tapping \ knocking sound from driver side cylinder bank
Details:When the engine is at operating temperature there is a clattering sound coming from the engine bay under slow acceleration from 0 to about 40km\h (2nd and 3rd gear). This is normally evident when taking off from an intersection but is also present on the motorway about 100km\h while accelerating gently. Usually occurs between 1500rpm and 2000 rpm.Once you open the bonnet the sound is obvious and is coming from the driver’s side at the front of the motor. Using a screw driver to my ear I was able to pinpoint the noise to the lower front side of the motor.The tab that holds a bunch of cables seems to have the cleanest sound (circled in red).When you repeat these steps on the other side of the engine there is no noise present.
Problem:
By the way is the noise present in neutral when revving for you? Thanks for the detailed post again.
Little bit of info about bleeding lifters
https://itstillruns.com/bleed-hydrau...s-7693426.html
If you had your oil drained and air got in somehow this would explain the noise i guess.
Will update with a complete sitrep once i get the car back.
Anyways, perhaps somehow during this repair air got in? I'm not too mechanically inclined but the entirety of my repairs were a condition before I purchased the vehicle.
After the repairs were all done I then heard the noise. Everything else about the car is fine and doesn't appear to have any leaks. Keep us posted.
I know that it is something but they couldn't figure out what it was. I doubt the ticking noise i can hear with the screw driver is the same noise i hear in the car (since i can barely hear it witht he bonnet up). Might be something lose underneath like an exhaust shield or something in the CATs rattling around.
