C63 AMG (W204) 2008 - 2015
Question about 2013 C63 Sedan Front Brake Pads&Calipers
Old Feb 28, 2019 | 03:36 AM
clutchfactor's Avatar
2013 W204 C63 AMG Sedan
Question Question about 2013 C63 Sedan Front Brake Pads&Calipers
Hello everyone, I own a 2013 C63 AMG Sedan. My front brake pads and calipers are needed to be placed according to the dealership and they ask for insane money. So I am wondering has anyone changed his/her front brake pads&calipers outside of the dealership? If so how to make sure the parts are legit? Thanks a lot.
Old Feb 28, 2019 | 03:53 AM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
..why do the calipers have to be replaced?
I had my calipers replaced about a month ago, but it was under warranty due to the paint flaking off of them.
Old Feb 28, 2019 | 04:11 AM
Catchyname's Avatar
2012 C63 w204 sedan
Do you mean rotors? Not calipers?
if so its an easy DIY and single piece rotors are cheap.
Old Feb 28, 2019 | 04:13 AM
Thats what the dealer told me. My car right now has 31500 miles on it. How much did you pay for the calipers?
Old Feb 28, 2019 | 04:24 AM
My bad, thats rotors need to be replaced actually. According to their health report about my brake status as the attached. Do you know where can i get the original rotors and discs without the dealer? They want me to replace right now but their asking price is absolutely insane.
Old Feb 28, 2019 | 04:25 AM
Sorry, I checked thats rotors are needed to be replaced.
Old Feb 28, 2019 | 05:55 AM
G_Money's Avatar
It was covered under CPO warranty at ~38-39,000 mi.
Old Feb 28, 2019 | 06:12 AM
Catchyname's Avatar
2012 C63 w204 sedan
I used FCPeuro.com they have both the one piece and two piece rotors and pads much cheaper than i could get from dealer.
other shops
ecstuning.com
pelicanparts.com
mboemparts.com
Old Mar 3, 2019 | 03:25 PM
zcct04's Avatar
C63 coupe, Z3M Roadster garage queen
It doesn't look like you are in need of an emergency repair. 4mm thickness is getting pretty close, and most sources suggest that 3mm is the minimum for normal street use. You started with about 12mm and used of 8mm over 31,500 miles, so you should have about 4 thousand miles left on them. It's perfectly fine to wait until the wear sensors get exposed and you get a warning on the dash.
If you have basic mechanical skills and tools, and take the time to study a couple youtube videos, you should be able to easily do this yourself.
Side issue - OEM brake pads are good stuff but there are lots of options for brake pads. Don't go cheap - they are important. Consider this an opportunity to get a pad that's less dusty than the OEM ones.
Old Mar 3, 2019 | 07:06 PM
///Bruce's Avatar
2020 AMG GTC Coupe & 2018 Macan Turbo
If you are gong to keep the car longer than the next 3-6 months and since you're going to need to pull the calipers to change the pads, you really need to throw on a new pair of rotors and not have to worry about it for quite some time. As far as pads, I am a very big fan of EBC Red Stuff. I have three qualifiers for pads: stop good cold, no noise and little-to-no dust. These meet all three. Just my 2 cents.
Old Mar 4, 2019 | 11:34 AM
Mort's Avatar
No need to pull the calipers if you are just going to replace the brake pads.
Old Mar 11, 2019 | 12:08 PM
zcct04's Avatar
Some people prefer to pull calipers and replace rotors when they replace pads, as this gives the pads a nice smooth surface to seat against. However, I'm with Mort - unless the rotors have really deep grooves, my preference is to keep the rotors until they wear down close to the minimum allowed. Your rotors should still be OK based on your low mileage.
Old Mar 11, 2019 | 12:17 PM
chad63's Avatar
C63 AMG
If you're in the GTA (Canada, Ontario) check out http://germanparts.ca .. they have reasonable prices for all c63 parts
Old Mar 11, 2019 | 01:36 PM
Yuille36's Avatar
Veteran: Marine Corps
07 E63 AMG, 10 C63 AMG, 07 E63 Designo, 07 E350, 09 C300, 07 C230
AMG rotors have a minimal thickness stamped on the rotors, unless your rotors have deep gouges and below their minimum thickness, I would just give them a good cleaning and change the pads.
But single piece rotors are cheap to replace, compared to the 2-piece rotors, why not change everything for peace of mind. I changed out my rotors and pads for just above $1000, and I have the 2-piece rotors on my 07 E63.
