C63 AMG (W204) 2008 - 2015
Any recommendations for Car Lifts? Eyeing an Elora for the stable...
Old Apr 16, 2019 | 09:30 AM
Dogtag114's Avatar
2009 c63
Anyone have a lift they love? Better yet an installer in NJ or an opinion that they are easy to install?
Also, eyeing a 2017 Lotus Evora 400, if anyone has an opinion on that.
Old Apr 17, 2019 | 12:36 PM
Adi-Benz's Avatar
2010 C300 4MATIC........ 2011 C63 AMG.............. 2015 CLS400 4MATIC.....
I always liked em
Not a very popular car though.
Old Apr 17, 2019 | 12:51 PM
Dogtag114's Avatar
2009 c63
It looks amazing, but test drive was very disappointing in the low end torque I’ve become used to.
i prefer the low V8 growl now... I’m cursed.
Old Apr 17, 2019 | 02:19 PM
BITRBO's Avatar
2001 Audi S4 Sedan (RIP) 2013 P31 W204 C63 (RIP)
I'm assuming this is for storage so you're looking for a 4pt, no? My dad is adding a 4th garage and putting one in to store toys, but not sure what brand.
But for maintenance/tinkering purposes, you're better off w/ a 2pt. I've got one at home and love it.
Old Apr 17, 2019 | 03:21 PM
Dogtag114's Avatar
2009 c63
It would be to maintain both cars in the garage and swap usage... I don’t tinker underneath enough to justify it.
Old Apr 17, 2019 | 03:35 PM
BITRBO's Avatar
Then 4 post is your Huckleberry. Good for storage and oil/fluid changes, but if you want to change wheels and/or do any kind of brake work, gotta get a 2 post.
Old Apr 17, 2019 | 04:04 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
home usable lifts can vary depending on budget...what is your budget...seems like money isn't an issue here.
money aside, this is my favorite lift for residential use. built in wheels allow the columns to unbolt and roll away when not in use.
https://www.maxjaxusa.com/dannmar-ma...d-package.html
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Apr 17, 2019 | 05:36 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
You will want a 4 post for storage, 2 post is in the way for the lower car and pain to put the car on constantly (but great for maintenance) and you need a minimum thickness of concrete to bolt them to, 4 post is not required to be bolted.
I have one of the ones that is sold as 100 different names, was about 2500 for an 8000 lbs (the one I have is from greg smith equipment) if you want to tire swaps and stuff, nice to get a jack that runs down the center and lifts on the 2 jack points (front or rear) at the same time to raise an axle. If I was to do it again, I would get a bendpak for 1000 more, they are a bit more but have some nicer features and are generally considered the one to get.
https://www.bendpak.com/car-lifts/four-post-lifts/
This is the one I currently have https://www.gregsmithequipment.com/A...rage-Pro-8-000
Old Apr 17, 2019 | 06:14 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Bendpak hd9 is the way to go. Get the hydraulic rolling jack with it and your set. Perfect for storage and pretty much any maintenance you need to do.
Old Apr 17, 2019 | 10:02 PM
MBNRG's Avatar
I would think one with ALI Certification (accredited by ANSI) has undergone more stringent safety standards/inspection. . .
Anyone with more knowledge know if ALI cert is indeed legit, or just another 'label' manufacturers pay to put on their lifts?
Old Apr 18, 2019 | 10:05 AM
BITRBO's Avatar
I looked into the MJ but finally settled on this one:
https://nationalautotools.com/collec...post-auto-lift
The MJ is limited to a 48" lift height since most home garages have ceiling heights limited to 7.5-8ft and that's about as high as you can go before the car hits the ceiling... But I got an extra 4-5" in clearance height with the above unit, plus an extra 1,000lb in capacity for the same price. I sacrificed portability, but that wasn't a major criterion IMO and I don't think anybody really does that anyway. You're sitting in a roller chair either way when working from below, but if I ever move to a house w/ a bigger (read: taller) garage, I'll be able to walk under it w/ this unit.
OP, check your ceiling height if you plan to get a 4-post and want to put another car under it...
Old Apr 18, 2019 | 03:34 PM
hachiroku's Avatar
SPONSOR
the benefits of a 4 post versus a 2 post...
4 post:
can park another vehicle under
easier and faster to use for simple tasks like oil changes
ease of doing home 4 corner alignments granted you have the required additions
2 post:
easier for anything suspension or 4 corner related
easier for full scale front end work like motor swaps
if it were up to me i'd have a 2 post on one side and a 4 post on the other side. but money doesn't grow on tree's in my household.
__________________
-BARRY
Old Apr 18, 2019 | 03:53 PM
ygmn's Avatar
2015 E400 Sedan
Talking
...: but money doesn't grow on tree's in my household.
Look out back they tend to grow there....
just remember if low roof make sure you have limit switch else you could get new addition above garage.
Old Apr 18, 2019 | 04:04 PM
BITRBO's Avatar
4 post:
2 post:
Agreed on most, except the bold/underlined... Unless you have an unsually tall ceiling in your garage, you ain't fitting fit much under there other than a Radical or a 4-wheeler. IDK, maybe that Lotus will fit, but better double/triple check just to be sure
Old Apr 18, 2019 | 09:46 PM
AMGonFire's Avatar
4 post:
2 post:
you can do all that stuff on a 4 post too. Is it easier on a 2 post yes but engine swaps ect ect can be done as well on a 4 post and suspension work can easily be done as well with a rolling jack. A 12 foot ceiling will allow for essentially any combination of cars for the most part.
