C63 AMG (W204) 2008 - 2015
Slight Steering Wheel Vibration - between 40-70
Old May 1, 2019 | 12:48 PM
James_'s Avatar
45k miles 2010 C63 AMG w204 / VW MK5 Gti
Earlier today, literally out of the blue the car developed a faint but noticable rhythmic thrum through the steering wheel, most noticeble between 40-70mph.
I've checked the air pressures, that is fine. I'm maybe thinking a wheel spat a weight off it and it needs balancing... but going around the car I noticed a piston looks to be coming up short on one of the rear rotors/discs (im UK but know my american friends prefer rotors ) .....
Could the brakes be causing the vibration? TO be fair, the brakes don't pulse or vibrate, but I know they are tired and will need doing sooner rather than later.
Any other thoughts on what might be causing the vibration - are more than welcome
cheers
Old May 1, 2019 | 05:54 PM
Ludedude's Avatar
2014 C63 Coupe
That's called "knockback" and is not uncommon. It's a bad surprise when you're looking for brakes right now on track but shouldn't be causing any vibration. First thing to check is wheel/tire balance. If you haven't done that yet, there's nothing to talk about.
Old May 1, 2019 | 05:58 PM
James_'s Avatar
Excellent - exactly what I wanted to know tbh. I've got it booked in tomorrow to get both of those looked at. It's just the way my head works that it has to know every damn possible cause asap, it's a **** trait
chrisridebike8's Avatar
'10 C63
Is that a picture of the rear caliper? You wouldn’t feel rear brakes through the steering wheel. Check the wheel balance.
Old May 1, 2019 | 06:02 PM
James_'s Avatar
Yeah that's a rear - now you've said it out loud, yeah how would that even work haha... it's been a long week.
Old May 1, 2019 | 06:13 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Bent wheel or warped rotors maybe?
Old May 1, 2019 | 06:20 PM
James_'s Avatar
Yeah I don't think that can be totally ruled out... but I didn't really do anything of note from it all being fine, to it not being, so it's the cause im struggling to attribute. I'll get the balancing done first, maybe it just spat a weight off, then go from there. The rotors all round are living on borrowed time, so if I have to bring forward changing them all then it won't be too traumatic
Old May 1, 2019 | 09:44 PM
AMG6.3's Avatar
C63
Balance wheel and or inspect wheels for cracks. A small crack in rim will cause vibrations
Old May 2, 2019 | 07:13 AM
James_'s Avatar
Okay so I had all my wheels balanced this morning, apparently they were out by a bit. They are also 'mildly' buckled - that's MB's 19s fo you, at least they weren't cracked.
BUT... the slight vibration, and its really slight - I just I know it wasn't there a few days back - is still present.
As they had the wheels off I could look at the front rotors properly and the inner face of them had; to use the tyre shops own words; 'fallen off'
So next job is to replace the front rotors, and see if that stops the annoying vibration.
