C63 AMG (W204) 2008 - 2015
Engine Code P228f help
Old Jul 29, 2019 | 11:26 PM
Noahh's Avatar
2015 C63 507
I have a 2010 C63 AMG and the yellow CEL is on. When I read the code it gives me "P228f - fuel pressure regulator 1 exceeded learning limits - too high"
I get 3 codes all reading the same thing (P228f)
I have no loss of power
noticeable loss in fuel economy
brief ticking coming from engine on cold start
previous owner said he replaced 2/8 fuel injectors so im thinking maybe its a couple more of those? Has anyone had this problem and what did it end up being? Any help is appreciated, thanks guys
Old Aug 15, 2019 | 04:23 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Any luck? I'm having the same code popping up with no resolution so far.
Old Aug 16, 2019 | 12:08 AM
Noahh's Avatar
2015 C63 507
Update:
Found a crack in my air intake manifold
replacing the whole thing in a few days and will report back if the rattle goes away. It was around $1000 after install (I got a used one) so not as bad as a camshaft repair
knock on wood
Old Aug 16, 2019 | 12:30 PM
chrisridebike8's Avatar
'10 C63
when I had that, accompanied with hesitation and stalling, it was my fuel pumps that died.
Old Aug 16, 2019 | 02:58 PM
Problem is my car runs completely fine. No hesitation, no misfires, no MPG loss, no noticeable power loss according to my butt dyno.
Old Aug 17, 2019 | 08:09 PM
WillA206's Avatar
Mercedes Benz C63 AMG
I had that, MB Seattle replaces the fuel pumps. Came back on in 2 months, now they’re saying it’s my fuel filter. $850 to replace that. We’ll see if that’s the cause
Old Aug 17, 2019 | 11:37 PM
Noahh's Avatar
2015 C63 507
I was getting power loss slowly over time as well as a high pitch whine
Old Aug 23, 2019 | 01:57 PM
WillA206's Avatar
Update on my car.. had a shop replace the fuel filter which Mercedes thought was causing the CEL. Turns out it’s the fuel rail censor that’s going bad. Wasted $900 for no reason.. my suggestion is to have multiple shops diagnose the CEL before you decide to do anything so you don’t waste money like I did!
Old Aug 23, 2019 | 11:34 PM
Noahh's Avatar
2015 C63 507
Did that replacement remove the CEL codes?
My engine started ticking loudly today too...
Old May 20, 2020 | 06:57 PM
mnshine54's Avatar
07 E63 AMG
I had exact same issue on my 07 E63. I replaced everything with the fuel system except for pump and sender. Still nothing.... check engine light is as bright as ever. then i tried opening the gas cap and leaving it off before starting the car. It worked immediately. Hope this helps.
Old May 21, 2020 | 02:56 PM
Had the same code and CEL. Car ran fine. After a suggestion from a member here (sorry, forgot the name), I had my fuel pump replaced and the code and CEL went away and has been away for a while now.
