C63 AMG (W204) 2008 - 2015
W156 Misfire
Old 08-23-2019, 01:11 AM
kkkk's Avatar
W204 C63 Estate
Have you done a leakdown test ?
Do you think it could be a timing issue or maybe the cam adjuster not adjusting the timing properly at that but low rpm
Old 08-23-2019, 01:19 AM
stereophile33's Avatar
2009 SL63
See above on leak down.
Cam solenoids and cam adjustment gears were replaced when heads were done.
Cause or symptom the injector turns off at light load intermittnantly
Old 08-23-2019, 01:47 AM
kkkk's Avatar
W204 C63 Estate
Both intake and exhaust cam adjusters were changed ?
Old 08-30-2019, 07:12 AM
kkkk's Avatar
W204 C63 Estate
I just changed all my plugs, and the injector and coil on cyl 7. Still misfires.
I did note that my exhaust cam positon values were fluctuating between -10 and +14 while cruising at that low rpm though
Both intakes were approx. +17 , and the other exhaust was about -6
Old 08-30-2019, 09:17 AM
2009 SL63
How did you capture/measure that?
Old 08-30-2019, 09:48 AM
kkkk's Avatar
W204 C63 Estate
Live data on a scanner
I have a theory though. Disconnect the cam position sensor on Bank 2. Go for a drive. See if it still misfires without the cam adjuster running.
If its fine, then its either the cam adjuster or the cam position sensor
Old 08-30-2019, 05:51 PM
  #32
2009 SL63
with those unplugged do they just stay in place?
Old 09-02-2019, 11:02 PM
  #33
kkkk's Avatar
W204 C63 Estate
I assume so. Might throw a code but at least you would be able to drive it and see if its misfiring or not.
Old 09-07-2019, 02:39 AM
  #34
knowbenz's Avatar
Benz
Originally Posted by hachiroku
no...the tune won't be specific to each bank. its pretty rare even with full standalones to allow for individual cylinder correction.
the M156 engine was CAD designed so I'd doubt the head flow characteristics to allow for a deviation of 11%. deviation is unavoidable with OEM built engines, but not of a spread of 11%. I'd look to maybe the possibility of air flow restriction of some sort? it wouldn't be a fuel flow issue as fueling will be based off metered air and oxygen sensor reading.
does your trims always have a 11% spread, or was it just this instance? my LTFT's with larger injectors and e85 tend to have a spread of about 3-7% at times, but never static.
anybody else here have any thoughts?
Exhaust restriction. If that scanner app has live data then monitoring STFT may help identify his issue.
Old 09-07-2019, 02:41 AM
  #35
knowbenz's Avatar
Benz
Do you have that Pico file still? Would like to look closer. Why is #2 pressure decreasing towards the end or am I seeing things?
Old 09-07-2019, 03:11 AM
  #36
kkkk's Avatar
W204 C63 Estate
I disconnected my exhaust cam solenoid and the misfire went away.
Old 09-09-2019, 03:35 PM
  #37
2009 SL63
I will be interested to see if it winds up being the solenoid, the plates or the sensor.
Have any of those been replaced yet?
Old 09-09-2019, 10:34 PM
  #38
kkkk's Avatar
W204 C63 Estate
Im just going to replace my cam adjusters. Cant figure out whether its the intake or exhaust so Ill just do both I think.
It could be the solenoid I guess, and could just try switching those first .
Old 09-09-2019, 10:45 PM
  #39
SPONSOR
hachiroku's Avatar
2007 Mercedes E63 AMG
same amount of labor do them at the same time.
Old 09-11-2019, 05:51 PM
  #40
2009 SL63
I have unplugged bank 2 solenoids and my miss also has gone away...
Old 09-11-2019, 07:22 PM
  #41
kkkk's Avatar
W204 C63 Estate
Getting close to a diagnosis now.
Its either the solenoid, or the adjuster then.
Swap the solenoids from bank 1 to bank 2 to begin?
Old 09-11-2019, 07:42 PM
  #42
Jasonoff's Avatar
Received 1,594 Likes on 938 Posts
2010 C63 AMG
Your adjuster is fubar man. It's obvious from the video you posted.
Old 09-11-2019, 07:55 PM
  #43
skratch77's Avatar
2005 E55
Not sure why one of the 5 shops that took his car apart didnt notice the car sounding like rocks in the adjuster.
Feel bad as they took him to the cleaners changing everything but the one thing that is making noise.
Old 09-11-2019, 10:44 PM
  #44
kkkk's Avatar
W204 C63 Estate
Yeah, the amount iv spent chasing this misfire has been extraordinary.
Old 09-12-2019, 03:12 AM
  #45
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
Do any of you guys have any weird sounding noises from the cam adjuster (intake)?
Im just wondering maybe someone skipped a step or something when putting the car back together after the headbolt install
https://www.youtube.com/watch?v=XhgVA6Ajm5w
Did your misfire come after the headbolt install dogtag?
What are your long term fuel trims like?
Oof that's brutal my guy, it hurts me just to listen to it... sounds like there are rocks in your valvetrain or something.
I hope you got that cleared up.
Old 09-15-2019, 12:38 AM
  #46
SPONSOR
hachiroku's Avatar
what does your cam timing read out when driving with solenoids unplugged?
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old 09-15-2019, 07:25 AM
  #47
kkkk's Avatar
W204 C63 Estate
With the exhaust cam solenoid unplugged, the exhaust reads at -15.
I havnt looked to see what it reads with the intake cam solenoid unplugged, or if it defaults to a safe setting with the exhaust cam solenoid unpolugged.
Old 02-19-2020, 11:42 PM
  #48
2009 SL63
What scanner did you use to measure this?
Old 02-19-2020, 11:44 PM
  #49
2009 SL63
update: Pulled bank 2 apart. Changed camshaft adjusters, cleaned and flowed injectors, replaced all coils (again), found a nose seal on the cam that was in the wrong slot. Got that fixed, everything back together. And guess what.
With brand new cam solenoids plugged in, misfire on cylinder 7 still present.
Unplug exhaust cam solenoid. Misfire goes away entirely....at this point I'm completely at a loss.
Old 02-22-2020, 05:43 PM
  #50
2009 SL63
bump?
Quick Reply: W156 Misfire
