C63 AMG (W204) 2008 - 2015
W156 Misfire
Old 02-22-2020, 05:53 PM
  #51
skratch77's Avatar
2005 E55
I would scope that cylinder and see how it looks and then check compression on it.
When you say misfiring is it pending and storing codes? Or are you looking at mode 6 data on misfires?
Old 02-22-2020, 07:04 PM
  #52
stereophile33's Avatar
2009 SL63
Compression and leak down is the best of all 8 cylinders.
Old 02-22-2020, 07:14 PM
  #53
skratch77's Avatar
2005 E55
is car pending codes for misfires?
Old 02-22-2020, 08:07 PM
  #54
2009 SL63
No. But it’s visible on the pressure trace.
Old 02-22-2020, 08:24 PM
  #55
Jasonoff's Avatar
Received 1,594 Likes on 938 Posts
2010 C63 AMG
update: Pulled bank 2 apart. Changed camshaft adjusters, cleaned and flowed injectors, replaced all coils (again), found a nose seal on the cam that was in the wrong slot. Got that fixed, everything back together. And guess what.
With brand new cam solenoids plugged in, misfire on cylinder 7 still present.
Unplug exhaust cam solenoid. Misfire goes away entirely....at this point I'm completely at a loss.
Is the EX valve not seating properly on #7 when the solenoid is allowing oil flow into the adjuster? An ex valve that's not closing properly can cause a misfire.
Old 08-31-2021, 01:23 PM
  #56
jaresmi's Avatar
W204 C63
Following up on this thread because I'm having the same issue now. Head bolts replaced last week in 2009 C63 and now there is a small misfire around 1500 RPMs, and OBDII error reads Camshaft position, intake/left/front bank 2 - timing over-retarded". They're advising to replace the cam adjuster. Would you please let me know what ended up happening with this thread and if there was a fix? Thank you!
Old 08-31-2021, 04:34 PM
  #57
Dogtag114's Avatar
2009 c63
I had to replace two camshaft adjusters on one bank shortly after my head bolts.
if your keeping the car long term, suck it up and replace all four. There are two for each side.
Quick Reply: W156 Misfire
