C63 AMG (W204) 2008 - 2015
Black Series Active Rear Differential Cooling
Old Feb 4, 2021 | 11:50 PM
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
Neat cooler instal.
Old Feb 5, 2021 | 05:41 PM
MBNRG's Avatar
So glad Michael Long and BENZTEC can do the project justice.
CAN'T WAIT TO SEE THE BEAST ON THE PROWL ONCE MORE, BROTHER
Old Aug 14, 2022 | 05:03 PM
Denior's Avatar
E500 w212, C63 W204
Thislook like BS diff cover. It has "normal" part number, same as euro cover with passive cooling.
Diff cover from BS
Old Aug 22, 2022 | 02:45 PM
Vladds's Avatar
2010 C63 2019 GLA45
What is the logic of function of the active cooling in the OEM BS? Is there a temp sensor and wiring harness maybe to the rear SAM?
To where the rear SAM can be coded with the Black series logic in it?
Old Jan 7, 2023 | 10:47 AM
Amit1411's Avatar
sls roadster
CLK differential pump
Is it still possible to get hold of a rear differential pump and cooler for the CLK black series and are there any alternatives? Thanks
Old Jan 7, 2023 | 11:36 AM
Dr.Speedfellow's Avatar
W204 c63
I can't speak to diff pump alternatives but my experience is that passive cooling (finned diff cover and rectifier) along with os giken diff that has cooling passages built in, and os gikens recommended super duty gear oil was up to the task of the SCCA Time Trials National event at Sebring in 90+° temps, several sessions per day for 3 days straight. So unless you are just going for some overkill spec or planning to run endurance events then active cooling probably isn't necessary.
Old Jan 7, 2023 | 03:50 PM
  #32
Amit1411's Avatar
sls roadster
hi it’s actually because the pump has corroded. I assume we have to replace whole unit or can we manufacture the part that corroded as it’s pure aluminium . Picture attached
Old Jan 8, 2023 | 11:29 AM
  #33
Diabolis's Avatar
W204 C63 Coupe, W166 ML350 BlueTEC, 928GT, Taycan GTS Sport Turismo, C5 Z06 & IS300 race cars
If you can't get an OEM replacement and are simply looking for a functional equivalent, a Tilton oil/diff cooler pump in place of the OEM one should work just fine. It is held in place by two worm gear clamps. You may need to get an adapter for one or both of the fittings depending on size, but that should be about it.
Old Jan 10, 2023 | 05:13 PM
  #34
C63 BS Black's Avatar
C63 BS Magno Night Black
AMG Mercedes Hinterachs Ölpumpe A 209 260 00 90 CLK W209 A2092600090 Black Serie | eBay
Mercedes AMG Hinterachs Ölpumpe A 209 260 00 90 CLK W209 A2092600090 Black Serie | eBay
