C63 Black Series - can I add Euro seats & Track Pack?
seats on the other hand, quite costly, i got a quote almost 10 yrs ago when i was shopping for the Euro spec seats for my CLK63BS, ended up sticking to the original Euro spec CLK63BS cloth seats at the time because the Euro spec C63BS buckets would cost around double than the Euro spec CLK63BS seats back then.
having had that experience, when it came time to source the C63BS, i made sure to acquire an Euro spec C63BS that already came with the bucket seats/solid roof/no reflectors, so i didn't need to spend that much $ on the complete Euro spec conversion like i did with the CLK63BS; i think when i priced out the entire Euro spec conversion on an American spec C63BS, the total, in parts alone, was somewhere between $40k~$50k shipped, and the seats alone with brackets/sliders/etc were nearly half of that cost.
if you don't want to fork out that much $, and not over 6' tall or weigh over 200lbs, just buy a pair of Recaro Pole Position, they're the closest thing to the buckets in the euro spec C63BS, just a bit narrower & not in the same upholstery.
and although the OEM AMG buckets are nice to have...they're simply rebranded Recaro Pole Positions. you could order them in a higher model carbon fiber shell, add base mount, add universal sliders, then recaro side brackets and you'll be in cheaper than the factory seats but in carbon fiber. hell, you could even have them reupholstered and have the AMG stitching done if you wanted them to look authentic.
https://www.recaro-automotive.com/us...osition-ng-fia
https://shop.redline360.com/products...passenger-side
edit:
as mentioned by another member the pole positions are slightly different. still most likely manufactured by recaro. the AMG versions have some widening of holes for the seat buckle, but also so it has some extra room on the side bolsters of your thighs when you are seated.
They are the version used in OEM cars that have Recaro fixed back seats (Porsche/MB-AMG/Aston Martin/etc)
https://www.recaro-automotive.com/en...e-position-abe
I have had these on one of my cars and they are amazing for a streetable fixed back seat, super comfy and very supportive
Evosport did my seats for the clk bs which were identical to the euro spec in 2012:
- dtm sparco seat - carbon fiber shell - leather/alcantara - $5400 (2 seats)
- side/bottom mounts w/ sliders - $880 (2x)
- sparco seat universal track set (sliders) - $162
- srs sensor - $1215 (install/labor/retrofit seatbelt = roll bar)
Thank you.
not to mention other sought after optional parts - the carbon aero wing assembly is around $10k, carbon front splitters are around $6k, the carbon side mirror assembly is also around $8k... so $6k for the whole track pkg cooling assembly doesn't surprise me at all...
