#mag1c_carp3t
What are your wheel and tire specs now? And are you running rear fender liners or did you remove to fit more tire back there?
Also, did you order those tires with white letters, paint them, or use a sticker kit?
I can't see anything on the body mods
Can you lost and enlighten me?
Also. Noticed you're selling a lot of stuff. Are these extra parts , or going a different route?
Parting the car out?
Edit: Stock fender liners just trimmed the part that turned down. I would say this is a hard tire to fit even at max height on KW V3 coils. Would still rub on hard bumps.
https://mbworld.org/forums/c63-amg-w...r-fenders.html
Yes I am parting out now.
https://www.autotrader.com/cars-for-...ngId=511301804
"This is your chance to own a 550hp show car for $25k! CLEAN TITLE no damage no accidents 2009 C63 AMG. Car is wrapped in Avery Intense Blue vinyl. I will list some of the main modifications below. Vehicle has over $30k invested into it in updated oem parts and aftermarket modifications. Receipts for all maintenance and repairs done on hand. The dreaded defective headbolts and lifters have already been replaced for you that plague other M156 motors."
- Eurocharged V7 Tune 444whp/407wtrq on 91oct. Tune is done via an included vin locked handheld tuner allowing you to change the maps yourself.
- ammfab PNP Heads.
- aFe pro dry drop in filters
- UPD billet pulleys.
- Wavetrak LSD.
- Kmac bushings on all arms allowing for full camber, toe and caster adjustability all around.
- Custom Metal Widebody done locally by slickshot.
- ADV.1 ADV15 Track Function wheels 19x10/19x11.
- Toyo Tires Proxes R888 265/30ZR19 295/30ZR19
- New oem radiator. New oem valve body. Fresh transmission fluid. Fresh differential fluid New oem mcu and engine harness. New fuel tank sensor. New o2 sensors. New spark plugs. New injectors.
