C63 AMG (W204) 2008 - 2015
Mode 6 data, and left bank misfire.
Old Sep 3, 2019 | 11:22 PM
kkkk's Avatar
W204 C63 Estate
Does anyone know what the Mode 6 values in Torque refer to?
I have the left bank of my car misfiring and and after a one hour drive here are the misfire counts on Torque
Cyl 1 0
Cyl 2 0
Cyl 3 0
Cyl 4 2
Cyl 5 13
Cyl 6 29
Cyl 7 324
Cyl 8 21
The only thing that flagged to me in live data was
MID: $36 TID: 84
Min 6.14 , Max 27
Current Value 1.4
This was highlighted as out of range. However, on a refresh it would be within range. Does anyone know what this value is for?
I also got live data with the car and noted the "camshaft position exhaust left" fluctuates wildly, from a negative value to a very positive value, up to +14. If I compare the values to camshaft positon exhuast right, they are wildly different and tend to stay negative.
The following video is at 1200-1500rpm
The car also has the following ticking noise from the left camshaft adjuster area
Spark plugs are brand new, Injectors and coil packs are new. O2 sensors are new.
Compression test was good, so was a leakdown test.
Misfire happens at 1200-1500rpm in that range. When the car is first turned on in a cold start, there are no misfires , especially if I keep it driving under 1500RPM. Once I start to drive normally, the misfire count will go up on cylinder 7 at the 1500rpm mark. Past 1500RPM, the misfire dissapears.
I have no fault codes.
This all happened after a headbolt install
Questions:
1. What is MID: $36 TID: 84 measuring?
2. If I unplug the connector to the left intake or exhaust camshaft adjuster , will the car still run, or is this a bad idea?
3. Does a "camshaft position exhaust left" mean that the camshaft adjuster is bad, or the exhaust cam position sensor? I can easily swap the left and right cam position sensors.
Old Sep 4, 2019 | 08:56 AM
skratch77's Avatar
2005 E55
I would change that side cam adjuster and see if that helps.its making a mechanical noise and not sure why you haven't changed that out first.
Old Sep 4, 2019 | 06:52 PM
kkkk's Avatar
W204 C63 Estate
Is there any way to tell if it’s the exhaust or intake cam adjuster causing this issue ?
is there any way to disable the cam adjuster to aid diagnosis ?
Old Sep 4, 2019 | 07:53 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
can you unplug them? if so and its safe to do so i'd start with that. i'd confirm that it is safe to do so and if its possible.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Sep 4, 2019 | 11:00 PM
kkkk's Avatar
W204 C63 Estate
Im assuming you mean unplug the cam position sensors (235/240). What about part 230, is that a solenoid? could that be making the noise?
Old Sep 4, 2019 | 11:04 PM
skratch77's Avatar
2005 E55
Please dont unplug you cam adjuster and run the car.
Old Sep 4, 2019 | 11:44 PM
kkkk's Avatar
W204 C63 Estate
I don't think that's possible. Im just wondering if I unplug the cam position sensor or the solenoid and run the car, it would disable the cam adjuster and somehow bypass it .
Old Sep 4, 2019 | 11:59 PM
hachiroku's Avatar
SPONSOR
I don't know if it's possible or safe to do but you'll need to eliminate options when problem solving. generally speaking you cannot by computer lock a position but for instance for Audi's you can monitor requested and actual. if those differ you have an issue with a part of the mechanical system.
along with that start up has a set value and after stable idle you have another set value so in monitoring if they do not reach those marks than the timing adjuster is faulty.
we need a Mercedes master technician to assist with appropriate diagnosis here.
Old Sep 5, 2019 | 08:40 AM
kkkk's Avatar
W204 C63 Estate
Ill see if I can actuate the cam adjuster by supplying voltage to the cam solenoid.
This may or may not work
Otherwise Ill try to start the car with a disconnected cam solenoid to see if it can not activate /bypass the adjuster.
Also will try to disconnect the cam position sensor. Im sure it will still run disconnected.
Old Sep 6, 2019 | 12:06 AM
kkkk's Avatar
W204 C63 Estate
There are 2 connectors to the intake and exhaust cam solenoid.
Am I correct in assuming these adjust the cam adjusters?
When I disconnect the exhaust solenoid, there is no misfire.
However, when I disconnect the intake solenoid, there is also no misfire.
I guess it must be the cam adjusters causing this misfire then? The 2 must be linked or if one solenoid is disconnected, both the exhaust and intake must go into a default value.
Old Sep 6, 2019 | 12:25 AM
hachiroku's Avatar
SPONSOR
sorry I just watched your cam adjuster video...that thing is dead. replace it.
Old Sep 6, 2019 | 02:15 AM
kkkk's Avatar
W204 C63 Estate
Is there any way to figure out which cam adjuster needs to be changed? (intake or exhaust)?
Old Sep 6, 2019 | 05:52 AM
kkkk's Avatar
W204 C63 Estate
Currently driving with the car with the exhaust solenoid disconnected. The rattle noise seems to have reduced too. Misfires are gone . Is it safe to drive with the solenoid disconnected ?
Old Sep 6, 2019 | 01:16 PM
hachiroku's Avatar
SPONSOR
disconnecting would only assist with identification of the problematic adjuster/solenoid. without understanding the full sweep and operation of the adjustment range and behavior I would not advise driving the vehicle as so.
if you're able to get confirmation from someone who has this information, drive of low RPM shorter distances should be fine if they deem it safe.
__________________
-BARRY
Old Sep 6, 2019 | 05:27 PM
kkkk's Avatar
W204 C63 Estate
From my quick observation the exhaust cam just stays locked at -15.
surely this has to be better than the exhaust cam changing from -15 to +9
Old Sep 6, 2019 | 05:31 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Why don't you just replace it and stop fkn around?
Old Sep 6, 2019 | 05:37 PM
kkkk's Avatar
W204 C63 Estate
Still trying to figure out whether it’s the intake or the exhaust cam adjuster , or the solenoid , and need time to gather the funds.
Each adjuster is $1500 each and then there’s the labour which is about $1000
Old Sep 6, 2019 | 05:40 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
CAs are not 1500, https://www.ecstuning.com/b-genuine-...ch/1560503747/
https://www.fcpeuro.com/products/mer...mer-1560503747
You can find them cheaper than that as well.
Old Sep 6, 2019 | 05:53 PM
kkkk's Avatar
W204 C63 Estate
Thanks. That was Australian dollars not US dollars . Once converted and shipped they are still $1k each
Old Sep 6, 2019 | 07:30 PM
skratch77's Avatar
2005 E55
Parts.com had them for 500
Old Sep 6, 2019 | 10:57 PM
kkkk's Avatar
W204 C63 Estate
Parts.com is no longer processing new orders.
We appreciate your business and look forward to the opportunity to work with you again in the future.
Old Sep 7, 2019 | 12:48 AM
skratch77's Avatar
2005 E55
Before you start buying things I would open up the valve cover and see what you need.
To do it right though I would get new cam,gear and lifters etc.
Old Sep 10, 2019 | 03:09 AM
kkkk's Avatar
W204 C63 Estate
Does the camshaft adjuster solenoid make any noises ? Or all the noise would be from the adjusters ?
Old Sep 10, 2019 | 11:10 AM
hachiroku's Avatar
SPONSOR
solenoids should click if any noise but usually are quiet and shouldn't tick. if a solenoid is bad you'd lose function and receive a code I would assume.
camshaft adjusters are known parts that wear out over time. start with those. they are a known failure item.
honestly speaking someone should be able to tell you the correct diagnosis and monitoring of them using Star/DAS if you are wanting to be 100% sure. in either case that video shows and sounds like they're no good.
better yet...have you done an engine flush and then replaced your oil with something good? that helps a lot but doesn't solve an issue if your adjusters are really dead. btw, they sound bad/dead.
Old Sep 20, 2019 | 12:21 AM
kkkk's Avatar
W204 C63 Estate
OK Iv got more data for analysis, before I go out and buy some adjusters?
-With the Left intake solenoid disconnected, The left camshaft position is stuck at 28 degrees. The left exhaust camshaft position does not line up sometimes with the right camshaft position. Timing of the R and L bank is the same. No misfires
- With the left exhaust solenoid disconnected. The left exhaust position is stuck at -15degrees. The left intake camshaft position is pretty much the same as the right intake camshaft posiiton. Timing of the R and L bank is the same. No misfires
Now, this leads me to hypothesise that the left exhaust solenoid or the left camshaft adjuster has has issues.
If this is true, shouldnt the car still misfire with the left intake solenoid disconnected, as the left exhuast camshaft is still giving erroneous values? Is there anything else that is switched off or disabled when the a camshaft solenoid is disconnected?
