C63 AMG (W204) 2008 - 2015
C63 vs C350 differences?
Old Nov 15, 2019 | 04:25 PM
bowenxue98's Avatar
2014 Mercedes C350 Coupe
Hi guys,
Maybe you can help me clear up a few points. I really don't understand the major difference between a c63 and a c350. I know that a difference is the engine, but otherwise, are there any other real differences? Both use the same chassis (family sedan car), and perhaps the c63 has stiffer suspension, but that can be easily upgraded in a c350. Just trying to understand the additional cost of the c63 over the c350.
Old Nov 15, 2019 | 04:28 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
Engine
Brakes
Suspension
Driveline
ECU programming
Certain body parts (wider front fenders, hood, bumpers, ground effects and spoilers, etc)
A better question would have been what’s the same. That list is shorter. Chassis, interior, most of the body panels.
Old Nov 15, 2019 | 04:30 PM
bowenxue98's Avatar
Yes, but the chassis is most of the car. You can easily modify the other points (suspension, brakes, drivetrain like rear end, ecu) to be that of a c63 in a c350 for much cheaper than upgrading to c63.
Old Nov 15, 2019 | 04:51 PM
BalanBro's Avatar
2012 C63 P31 Sedan
None of the things you mentioned are cheap if you actually do them right, and in the end it'll still just be a V6. By the time you do all that, you'd have been better off just getting a C63 that would still blow a modded c350 away.
Old Nov 15, 2019 | 05:03 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Can you try it and report back?
Old Nov 15, 2019 | 05:11 PM
deadlyvt's Avatar
2010 C63 AMG
yes that’s a great idea ! And no quitting just because your costs have exceeded what buying a c63 would have cost!
Old Nov 15, 2019 | 05:12 PM
BLKROKT's Avatar
You're on drugs if you really believe that
Old Nov 15, 2019 | 05:24 PM
bowenxue98's Avatar
That is not true... The most important thing in the car is the weight balance. Both c350 and c63 have the engine out in front, far from the center of mass. The c63 is even heavier than the c350 due to the large engine.
Old Nov 15, 2019 | 05:31 PM
Vader27's Avatar
2010 C63, 2017 S63, 2018 G63
Yeah, you are probably right:
Brake kit: $4k
Suspension: $2-4k
Engine: Airflow/exhaust mods, too much forced air for long-term internals to make it long, and a tune sufficient to give you an extra 150 crank hp: $8-10k
Best-case scenario, you have a car with less torque, a much shorter peak HP curve, and have blown 12-15k on mods in a car that still won't outrun a C63 in any scenario, and you can only romp a few times before you are buying new car...
It's hard to fight displacement.
Old Nov 15, 2019 | 06:00 PM
J666's Avatar
E
Engine
Transmission
Rear axle
Drive shaft
Suspension
ECU
Programming
Exhaust system
Brake calipers & rotors
Wider body
Hood
I’m sure I’m missing dozens of others things. If you want to go that route, go ahead, but expect to pay easily over $15,000 to mod your 350 into a 63. In the end, you still won’t have an AMG.
Old Nov 15, 2019 | 06:04 PM
AMGonFire's Avatar
2012 c63 AMG, 2011 GLK 350, 2019 GLS 450
Pretty much everything is different. You will never make your c350 faster then or be a c63. Go drive a c350 and then right after go drive a c63. The differences will be obvious. Get a c63 and be done trust me. You won’t be disappointed. You will be disappointed after dropping thousands on modifying your c350 and in the end it doesn’t do any one thing better then what a c63 can do.
Old Nov 15, 2019 | 06:05 PM
BLKROKT's Avatar
Is there an echo in here?
Old Nov 15, 2019 | 07:10 PM
Panzerbiscuit's Avatar
C63 AMG
Now, if you want to modify a C180 that's a different story
Old Nov 15, 2019 | 07:36 PM
curt.r's Avatar
2013 P31 C63 Sedan
Hey guys... I think the OP is on to something. Let him mod the C350 to be a C63. Definitely gonna stand with OP on this one. After all, its just the engine, brakes, suspension, etc. No biggie, right?
Old Nov 15, 2019 | 07:43 PM
BLKROKT's Avatar
Subframe
swaybars
all wiring
Can the mods just end this troll thread please
Old Nov 15, 2019 | 09:37 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Couldn't agree more. Don't listen to any of these dipshis doubting you.
Most, if not all, have never turned a wrench...
I'll be gutting my C63 soon for a race car project. Hit me up if you need some interior bits on the cheap!
Old Nov 15, 2019 | 09:40 PM
Funkwagen's Avatar
2009 C63 AMG, 2010 C250 4Matic Sport
It looks a lot easier on paper than it actually is. Unless you're willing to spend a ton of time on all of these "easy" steps...probably just trade for a c63
Old Nov 15, 2019 | 09:54 PM
deadlyvt's Avatar
2010 C63 AMG
The weight difference is pretty negligible... 439lbs for the m156 vs 391lbs for the m272.... that 48 lbs difference you won’t notice...much if any. Plus the wider track and better geometry on the front suspension on the c63 would more than offset it in general handling characteristics.
Old Nov 15, 2019 | 10:20 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
The big difference is your C350 sucks and my C63 does not.
Old Nov 16, 2019 | 08:33 AM
Turkish05's Avatar
C63 soon
The 6.2 litre v8 is the diffrence
Old Nov 16, 2019 | 08:41 AM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
Old Nov 16, 2019 | 11:49 AM
1Lop2K5C's Avatar
C63
Sounds like OP is trying to prove the old "its nothing but a bigger engine" in a small car. Front suspension is completely different. I believe the 63 has wider front track.
Old Nov 16, 2019 | 04:39 PM
AMG6.3's Avatar
C63
Hum.... everything including the leather is nicer. Let’s be honest the C63 motor is worth more than C350.
Drive the one you will see and feel the difference.
Old Nov 16, 2019 | 05:04 PM
bowenxue98's Avatar
They are both entry level models from Mercedes. If anything, your c63 is in the same boat.
Old Nov 16, 2019 | 05:05 PM
bowenxue98's Avatar
Not sure if this is an exaggeration or if you actually believe this. How can an engine be worth more than a car + engine? If anything, the frame of the car is worth more.
