C63 AMG (W204) 2008 - 2015
Y air intake collector ( help)
Old Nov 29, 2019 | 07:53 PM
zeus_luis's Avatar
Mercedes c63 AMG
Any one can explain What is the purpose of these little box sitting on top of the Y intake collector. I found out by blowing air into the little tube on the bottom right corner that the box has some air leakage all around.. anything to be concern?!
Old Nov 29, 2019 | 08:15 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
I always thought it was some type of intake resonator. Blowing air pay cause the seal to open up while sucking air into the engine might not leak, I would test it when running on the car to see if it leaks. Other models with the M156 didn't have the box at all, so assuming it is something to help with intake noise.
Old Nov 29, 2019 | 08:18 PM
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
It’s a Heimholtz resonator to reduce intake noise. Or a brake booster canister. I’ve seen it described as both in various MB literature. It shouldn’t leak.
Old Nov 29, 2019 | 11:20 PM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
It performs magic... https://itstillruns.com/air-intake-r...-12156112.html
Old Nov 30, 2019 | 09:20 AM
Top Answer: 1
Well if it is called a pressure reservoir and it leaks when under pressure, certainly time for a new one.
Old Dec 1, 2019 | 12:38 PM
sventastic82's Avatar
2010 C63 AMG RIP. 2021 Toyota Tacoma TRD Off Road, 2013 C63 coupe
Here is my take on it.
It is a (vacuum) pressure reservoir (and a resonator in one). Being under vacuum and the highest pressure difference it could have compared to atmosphere would be around 0.5 to 0.75bar.
If you applied positive pressure higher than 0.75bar or 11psi to it could result in a leak because the reservoir isn't made to withstand higher or positive pressure.
Either you permanently damaged the seal or temporarily blew by it.
Just hook is back up and see if it leaks.
Old Dec 2, 2019 | 10:29 AM
Solo wing's Avatar
2020 E 300 Coupe and 2019 GLS 400
All M156 engines have a vacuum reservoir, older engines have a metal canister attached to the block I think. I don't know why they redesigned it. I attached a WIS PDF showing the difference.
File Type: pdf
Old Dec 2, 2019 | 10:55 AM
skratch77's Avatar
2005 E55
You have a part number for that canister?
Old Dec 5, 2019 | 01:11 AM
Solo wing's Avatar
Sorry for the delay,
Looks like the black reservoir was used initially with the W204 C63. As EPC shows it did not have the metal reservoir installed at all.
Keep in mind that part # A1560900329 can be used in any M156 regardless of the model.
Old Dec 5, 2019 | 04:35 AM
skratch77's Avatar
2005 E55
I'm trying to install the old setup on my c63 and was looking for the metal canister part number.
