C63 AMG (W204) 2008 - 2015
Best CA smog-legal tune?
Old Dec 21, 2019 | 10:17 PM
m a x i m u s's Avatar
C63 AMG P30 *EuroCharged*| Porsche Cayenne | Buell XB9SX
Any recommendations on the best CA smog-legal tune for our cars? I currently have EC, but I have to keep flashing back to stock when I go in for a smog check. After an ecu scare this year, I'd like to just tune it and not mess with it (after a recommendation from another member whose name I don't recall, apologies).
Old Dec 21, 2019 | 11:57 PM
G_Money's Avatar
'04 E55 (Gone but not forgotten), '13 C63 P31 (RIP), another '13 C63 PP
I'd reckon Weistec, Renntech and Kleemann. I think OE has one too.
Old Dec 22, 2019 | 12:24 AM
deadlyvt's Avatar
2010 C63 AMG
Do you have cat deletes? Otherwise I can’t see a tune making you fail emission, unless the tuners are shutting off secondary o2 monitors for some reason?
Old Dec 22, 2019 | 01:13 AM
Thanks.
Old Dec 22, 2019 | 01:15 AM
No cat delete, car is stock besides the EC tune. I know for a fact that not all of the monitors set when I have the tune on the car, I checked it with my OBD2 scanner.
Old Dec 22, 2019 | 02:17 AM
deadlyvt's Avatar
2010 C63 AMG
Did you check with ec if they will reset the monitors? Should be no reason they are off with just a standard tune
Old Dec 22, 2019 | 03:24 PM
I did email Jerry on Friday evening and I'm waiting for his response. I just thought I'd bother you guys here in the meantime. 😊
Old Dec 22, 2019 | 04:46 PM
roadkillrob's Avatar
Top Answer: 1
12 C63BS Magno Alanite Grey, 25 X5 Msport, 08 BMW E93, Ducati Hyper 698
Technically none are smog legal as none are certified, but any should go through smog if you have cats and the tune is not turning off the 02 monitors, my last EC tune had the monitors all active as I was stock and would go through any OBD checks.
skratch77's Avatar
2005 E55
I have a few oe files that keep all emissions system on including race gas files.
I'm sure any tuner can give you what you are looking for. I think the car runs better with them on. Throttle feels a little more sharper.
Old Dec 22, 2019 | 07:22 PM
Thanks, Rob. Are you in CA? You can PM if you don't want to publicize. I'm on my iPhone, so don't see if you've indicated your state.
Old Dec 22, 2019 | 07:23 PM
Thanks, man. I'll see what Jerry says. I guess I could always just try to smog it with the tune on and if it fails, then flash it back to stock, but I'm a little paranoid about flashing my ecu excessively after a recent scare, which I mentioned.
Old Dec 22, 2019 | 10:17 PM
hachiroku's Avatar
SPONSOR
2007 Mercedes E63 AMG
any tuner should be able to provide you the same tune with or without cat deletes.
ask for an updated EC tune. generally speaking, modifications to engine computers of any kind is not legal.
__________________
-BARRY
​​​Follow us on instagram @eightysixtuned
https://www.eightysixtuned.com
Old Dec 23, 2019 | 01:46 PM
As you guys have said, Jerry replied that it won't pass if catless but should pass if catted. I guess I'll stick with my V5 and cross my fingers. Thanks, all.
Old Dec 23, 2019 | 02:59 PM
EkS's Avatar
EkS
C63
You're wrong. The Weistec Stage 1 tune has CARB EO# D-691-3, meaning that it's smog legal for use in CA. Not many tuning companies go through the process of getting their tune smog legal.
Old Dec 24, 2019 | 12:38 PM
Top Answer: 1
Good to know, I knew they had a carb legal blower setup, didn't realize they certified a standalone tune, so guess there is one option then that is smog legal.
Old Apr 13, 2021 | 02:02 PM
svmf2b's Avatar
G500
Just passed California smog following Renntech HHT tune on my G500 (m113 5.0) =)
Only other mods were K&N air filters, deleting middle muffler, and upgrading to Magnaflow mufflers after cats. No warning lights after tune. I was scanning this post prior to going in for a smog check, and decided not to flash it back to stock prior to the check, so wanted to follow up.
Old Apr 13, 2021 | 04:14 PM
hachiroku's Avatar
SPONSOR
for those interested all of my tunes are sold with emissions intact.
__________________
-BARRY
