C63 AMG (W204) 2008 - 2015
C63 AMG Oil Cooler solution! Reasonable 44O option!
Old Oct 31, 2023 | 03:59 AM
  #351
SRG_C63's Avatar
C63 AMG PP+ 2010
Originally Posted by ruxa222
How can i buy this oil coolant.i send message on gmail
@SRG_C63
I respond to every email promptly. There are currently no unanswered ones. Check your spam folder.
Old Nov 6, 2023 | 05:24 PM
  #352
SRG_C63's Avatar
C63 AMG PP+ 2010
Hello everyone,
I was wondering whether there might be a possibility to offer a reasonable plug and play solution for a transmission oil cooler.
Would anyone be interested?
Old Nov 6, 2023 | 08:54 PM
  #353
Phil_T's Avatar
C63 AMG Saloon
Originally Posted by SRG_C63
Hello everyone,
I would be interested, already bought the main cooler from you too. Where you thinking for the mounting location? As I was going to do what a few others do and put it in the opposite side lower outside grill.
Old Nov 6, 2023 | 08:55 PM
  #354
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
Hello everyone,
What did you have in mind? Over the winter (now'ish - march) I was going to cut the hard lines and adapt to AN fittings so I can fit in a larger cooler.
It doesn't need much. Just something a little larger should do the trick.
Old Nov 7, 2023 | 04:43 PM
  #355
SRG_C63's Avatar
C63 AMG PP+ 2010
It was supposed to be something similar for me.
However, I don't have a location for the new radiator yet. It also needs to be attached with a proper bracket.
Old Nov 7, 2023 | 06:01 PM
  #356
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
I don't have an AC condenser so I have some placement options. I was also considering to re-task my trans cooler for additional power steering cooling capacity.
Old Dec 19, 2023 | 09:28 AM
  #357
SRG_C63's Avatar
C63 AMG PP+ 2010
Hello,
Are there any new experiences with the
cooler on the race track?
Old Dec 28, 2023 | 05:32 PM
  #358
Adam683's Avatar
Porsche
Originally Posted by Cwagon
I used a silicone cape and race tape that I had lying around, fitted tightly over the plug.
Then placed the wiring up as high as it would go with the cap looking up so any water would just run down.
Just placed my order with Sven for my 2012 C63 coupe. Really excited and will report back as soon as it’s received and installed/tested!
Old Jan 19, 2024 | 05:23 AM
  #359
Phil_T's Avatar
C63 AMG Saloon
Hello,
Any news on a trans cooler?
Old Feb 3, 2024 | 09:53 AM
  #360
SRG_C63's Avatar
C63 AMG PP+ 2010
Not yet. Unfortunately, I have a lot to do at work at the moment and my oil temperature from the gearbox is not causing me so many problems. Only very, very rarely.
Old Mar 5, 2024 | 12:50 PM
  #361
SRG_C63's Avatar
C63 AMG PP+ 2010
Important info:
All orders received until 03/31 will be shipped until 05/01.
After that, the next shipment will not take place until August due to private circumstances!
Old Mar 5, 2024 | 02:03 PM
  #362
mthis's Avatar
Anything W/4Wheels
How do i go about ordering.
Old Mar 5, 2024 | 03:40 PM
  #363
SRG_C63's Avatar
C63 AMG PP+ 2010
Write me a Email: srg_c63@gmx.de
Old Mar 5, 2024 | 05:05 PM
  #364
BLKROKT's Avatar
2012 P31 C63 Coupe Trackrat, 2019 GLE63S Coupe Beast
If it helps, here’s the parts list for my aux trans cooler, which connects to the Weistec trans pan. Fits right in the drivers side bumper opening. You’d have to remove the windshield washer reservoir and/or install a smaller one for this to work. This doesn’t include the AN lines which I had custom-made locally by DYME.
Old Mar 5, 2024 | 06:21 PM
  #365
mthis's Avatar
Anything W/4Wheels
Done Ty
Old Mar 6, 2024 | 12:38 AM
  #366
Phil_T's Avatar
C63 AMG Saloon
Thanks, I also got some help from @sickSVT with his setup but he uses the setrab cooler below which I think I checked was the same of similar size to yours.
https://www.merlinmotorsport.co.uk/p...-female-std625
I just need to buy it all as some parts are from the UK and others I have to get from the US. I was waiting to see if @SRG_C63 trans cooler placement was and what needed to be done to the washer bottle as we need that here in the UK 😄 Then it’s a matter of finding a shop that does this type of work which is hard to find someone who can do custom stuff, thats worked on Mercedes & that is familiar with trans coolers. I think I have found one shop but it’s a 4 hour round trip.
Old Mar 7, 2024 | 05:57 AM
  #367
DRBC43AMG's Avatar
As you are in the UK, perhaps you could get in touch with these people: Mercedes Benz & Smart Specialists | Prestige Car Service | Horndean, Hampshire
Oliver Stoner is a very knowledgeable guy and I can vouch for him
Old Mar 7, 2024 | 10:45 PM
  #368
Phil_T's Avatar
C63 AMG Saloon
Yeah I have spoken to Ollie before about other things but he is too far from me, I will be using JM Imports for the install as they do all types of cars plus do oil coolers etc with their big build GTR’s
Old Mar 20, 2024 | 06:29 AM
  #369
SRG_C63's Avatar
C63 AMG PP+ 2010
Last chance!
Old Mar 20, 2024 | 12:25 PM
  #370
acd683's Avatar
2019 G63
Hi all,
I wanted to quickly relay my experience with Sven!
I have a 2012 C63 Coupe with 42k miles. I've owned the car for about 1.5 years and drive it sporadically in the canyons in and around Los Angeles. Under a load, it was not uncommon to go into limp mode and see oil temps at or above 276F. Obviously this was super alarming. Pretty much the only place I could enjoy my car was Angeles Crest, at night, in the winter (temps would still hit 260F sometimes).
I contacted Sven in December and ordered his oil cooler hoping to rectify the issue. After a very easy transaction, fabrication began and just over a month later I had my cooler in hand. My shop installed it in a couple of hours and relayed they were very impressed with the size, design, and ease of install.
It obviously isn't summer yet, but the effectiveness of the cooler is clear. I would guess my highway temps (in manual mode, with some aggression) do not break 239/240F. Previously, this would be around 260F.
I did a drive with several Porsche friends to Death Valley last weekend. Under these conditions (flat road, 72F ambient temp, manual mode, speed about 90-100mpg consistently) we did not break 239F.
I cannot wait to get it in the canyons this summer. All signs points to success.
Also, temps return to normal far, far quicker than the standard cooler.
BIG IMPROVEMENT!
thank you Sven
Old May 25, 2024 | 01:12 AM
  #371
Phil_T's Avatar
C63 AMG Saloon
I totally agree with you.
You don't need to remove any radiators. The car has no problems with the water temperature or with the functioning of the air conditioning. This is a waste of time.
The FMU cooler is simply much too thick. The best cooler is as thin as possible and as high and wide as possible.
However, since this is not possible in modern cars, the radiators have to be a thicker and smaller. Any cooler thicker than 50mm will not work efficiently. I got this statement from the radiator manufacturer.
Additionally it could be that the cooling cores from the FMU cooler were of bad quality. But I am not sure about that.
If I had built the cooler like on the pictures, it would have cost much more.
Compared to the 44O kit, my radiator has the same cooling surface in combination with the original wheel arch cooler.
What you could do additionally is to install the SLS wheel arch cooler. This fits plug and play and costs about 1500$ in addition to my front radiator.
Then you have the largest cooling surface you can get on this car without major modifications and a better self made 44O Kit.
Sven can you help with what is needed to do this? (Part numbers and parts needed)
If I look at the part numbers from the 44O pdf this is what I see below but unsure what I need/dont need. I think the hardest part might be the actual oil lines as they won’t work with your cooler because of the mounting position.
A1975001600 - Cooler
A2045004000 - Holder bottom
A2045004100 - Holder top
A2045005500 - Holder left
A2045005600 - Holder right
A2315040112 - Rubber bearing x4
A2045005400 - Airguide rear
A2045050100 - Sealing Strip
N910112006003 - Screws x4
A2045003900 - Airguide front
A2045230000 - Strut
A0019902356 - Clip nut x2
A1685452328 - Seal
A0005456280 - Plug
A2048800700 - Wheel Arch Panel
Old Jun 16, 2024 | 08:20 PM
  #372
Lemons6245's Avatar
2015 C63
Just picked up my car from having the cooler installed Saturday. Already noticed a big improvement in temps staying more consistent and under more sprinted driving in M mode never saw above 231. I do notice that temps seem to raise faster when getting on it though. It’s quick to go from 220-230 when really beating on the car when I didn’t see that with the stock one as quick. I did have the shop remove the fender cooler fan, but they also remove the ducting as well. Are people mainly running with no ducting or ducting without the fan?
also looking into the SLS fender cooler it looks like the in and out ports are different then the one in the car right now, but online parts catalog seems to say it will fit a c63. Has anybody actually upgraded the the SLS fender cooler?
Old Jun 17, 2024 | 12:30 AM
  #373
Cwagon's Avatar
2013 W204 C63 AMG P31 Estate wagon
I too removed my auxiliary fan but left the ducting in place.
The standard ducting isn't as good as that of the 440 oil cooler package from AMG but does still have some ducting effect.
I also opened up the holes in the undertray behind the new cooler and included a rubber drop spoiler in front of the holes (similar to the 440 Pkg) to create a low pressure area behind to help suck air out from behind the cooler.
Old Jun 28, 2024 | 05:31 PM
  #374
Lemons6245's Avatar
2015 C63
I recently reinstalled the ducting without the fan and everything is much more stable now. Temps are consistent between 220-230 when beating it up on the street. In fact I have to hold RPM's between 3.5-5k moving in traffic to get the temps to raise. When I make a pull it brings the temps back down to 224-226. As for the undertray I used the fins that SRG supplied with the cooler. Everything is working perfect.
What I have been looking at since it looks like the SLS cooler is not a direct swap is at least maybe trying to use the front and rear ducting from the 44O kit. The front might work possibly, but the rear there are no studs on the back side of the factory wheel arch cooler, so I guess that wont work.
Old Jul 4, 2024 | 02:38 PM
  #375
Accidental L8 apex's Avatar
2013 c63 Magnuson SCed
Inquiry sent to email. I'm too young for limp mode. 🤔
You have already rated this thread Rating: Thread Rating: 5 votes, 5.00 average.
