C63 AMG (W204) 2008 - 2015
Ugh. Oil Filler Cap Broke
Old Feb 15, 2020 | 12:20 AM
Dogtag114's Avatar
2009 c63
So, cold night, about to top off the oil and the cap broke in three like a cracker. One piece fill below, clear to the bottom.
I assume I can’t drive like this. Just put a rag and wrench on it to remove when I get a new cap? I clearly don’t want any plastic in there.
Old Feb 15, 2020 | 05:26 AM
optimusprime m1's Avatar
W124 260E
Did the other part fall inside the engine if it did then yes you dont want to drive with it in there But if i now read it another way,. is that the broken part from the filler cap fell in to the bottom of engine compartment .If this is right just try and put a cap of some sorts over the oil filler port but dont not sealit it of because it needs to breath .
Old Feb 15, 2020 | 10:33 AM
Dogtag114's Avatar
2009 c63
Autozone has a $7 cap they say is compatible. Any reason not to purchase as a temporary measure until I can get one delivered? Does this breathe differently than any other cap?
Old Feb 15, 2020 | 10:42 AM
W124 260E
Should be good as original . If its made to fit your engine .
Old Feb 15, 2020 | 10:51 AM
Dogtag114's Avatar
2009 c63
If so, I'll just put an AMG sticker on it instead of spending $35-50 (on line v stealership)
Old Feb 15, 2020 | 12:35 PM
deadlyvt's Avatar
2010 C63 AMG
The oil cap doesn’t “breathe” it’s a sealed unit. Cars run a pcv system instead of breathers and have since about 1970
Old Feb 15, 2020 | 01:04 PM
Dogtag114's Avatar
2009 c63
$9
Old Feb 15, 2020 | 01:05 PM
W124 260E
Well i say they do .Open one up and under the plastic in the metal base is a hole the size of a knob pin .
Old Feb 15, 2020 | 01:29 PM
deadlyvt's Avatar
2010 C63 AMG
The edge of the cap is sealed with a rubber o ring, there is no hole in the plastic to vent or allow the engine to breathe. Doing so would make the car fail every emissions certification test in existence
Old Feb 15, 2020 | 01:43 PM
Dogtag114's Avatar
2009 c63
No holes... tested with water and ripped it apart. The holes you see in the one shot are only from the plastic I chiseled off the back.
Old Feb 16, 2020 | 04:38 AM
W124 260E
Well must have changed them ,.take my hat off to you my friend .
Old Feb 16, 2020 | 09:02 AM
Jasonoff's Avatar
Top Answer: 3
2010 C63 AMG
If you had one with a hole, it was damaged.
