The mod bug has kicked in...
#51
2012 P31 C63
#52
no the flex commander is generic. Increasing flow with more e content. And vice versa. No generic tune will be able to dial in injectors almost twice the value of stock ones. Dyno’s are also a terrible way to tune. Street tune is the way to go. Also peak numbers mean dog ****. There’s guy that “make” 500whp that run 11.5-6 with tire and there’s guys that make 460 and run 11 flat close to tens.
#53
2012 P31 C63
#54
PeterA90...you're a guy who knows what he wants in life.
which companies increase the flow of factory injectors these days? in the past this process has resulted in unreliable injectors. wasn't sure these type of companies were still around. if so would like to learn more about them.
edit:
went on a rant about tunes but deleted. don't want to clutter the thread. carry on.
edit:
thebug44 (03-18-2020)
#55
those guys run on at Atco. New York guys have the fastest times. And half of them are spraying don’t believe everything you see lol
thebug44 (03-19-2020)
#56
edit:
edit:
I was reading into these guys https://fuelinjectorclinic.com/fuel-injector-modification
I guarantee EC used them on the original service...since not many companies offer this
Larger injectors require more work to tune in. As you discussed in our texts.
hachiroku (03-19-2020)
#57
2012 P31 C63
1. How do you determine your ethanol content? and
2. Do the injectors have to be e85 compatible? Idk if stock ones are.
#58
2) think of this. Your stock system can handling 10%e. And the is either ethanol compatible or not. E is more corrosive and doesn’t have the cleaning properties of pump gas. I recommend throwing in a bottle of fuel injector cleaner preferably some with PEA or running a tank of 93 every 5-7 tanks.
Besides this car runs best at e60 imho that’s 105+ octane...
#59
cool man...thanks for the info.
ya larger injectors will require a proper tune to make the best of it. the factory computer can compensate +/-46 on fuel trims until you run into adverse running conditions on larger injectors. before that all will run fairly fine.
thebug44, pretty sure you'll see that the factory computer with flex fuel sensor kit will run. if you don't want/have to waste the flash credits don't do it. I have HPTuners on those Bosch injectors running better than stock so no worries there. cold starts included. even in cold weather starts are not an issue.
#60
2012 P31 C63
Once this whole corona virus cools down i hope to go to the track
#61
HP Tuners for an American car is nothing like HPTuners for a Bosch Motronic computer. That was good advice someone gave you.
#62
2012 P31 C63
#63
2012 P31 C63
wiring isn’t the cleanest unfortunately. I think this is the best I can do. Tried tucking them under the rail close to the intake manifold as best as I could.
is it a bad thing having it like this close to the intake manifold like that?
#64
I was able to get my wiring tucked in parallel to the fuel rail and zip tied them in place. the intake boxes will fit fine but the foam isolators won't fit .
recently I installed some silver reflective fiberglass material from Amazon to the bottom side of my intake boxes. not as fancy as the gold stuff but something is better than nothing.
#65
2012 P31 C63
doncmleon (03-19-2020)
#68
everything fit perfect for me. Including the foam insulators.
#69
2012 P31 C63
finally all done with the car. Rubber items went on nicely. Some wires are a little close to the intake manifold but I am sure it won’t burn them at all.
2nd photo is the nasty area I put my box. I will fix that eventually but now... time to flash this tune and fill her up with some e85
#70
nice
#72
2012 P31 C63
#73
2012 P31 C63
Well it is time to filler up gentlemen. I am nervous but also excited. Last time I replaced injectors on my car I had a fuel leak. I pressurized the system didn’t see any leaks.
gonna start the car hopefully no leaks. And when you buy used parts you always have to be somewhat concerned if everything works correctly
doncmleon (03-20-2020)
#75
2012 P31 C63
Okay, some bad news. I am getting Cylinder 2 (P0302)
and Cylinder 5 (P0305) misfire codes. Also, C0700 but I don't think this one is as bad as the other two. Now I have to diagnose this and figure out what the problem is.
Does anyone have any ideas? I did upload the eurocharged tune also IDK if this could be causing an issue.
