Got an oil change and now my engine has been running warmer than before
After this last oil change a few days ago, same oil, I noticed the engine temperatures have increased more quickly and leveled out at a higher temperature. Before it would sit around 100C, now it sits at 105C when in comfort driving to/from work.
I plan to take it to the road course again next month and it's worrying me that there could be something wrong. The Merc dealer recommends 5w40. Should I get it changed to 5w40 or is 0w30 fine? Also are there any better oils for when I take it to the road course so it doesn't overheat as quickly?
Your whole top end is probably done also. You basically put water in there. Get that oil out of the motor asap.
In your case I would say the thinner oil cant provide the lubrication your engine needs and the additional friction is driving the temp up.
Good luck.
https://bevo.mercedes-benz.com/bevolisten/229.5_de.html
https://bevo.mercedes-benz.com/d/d/de/Spec_223_2.pdf
See the note regarding oil viscosity requirements for the M156.
Then there's that nonsense about not being able to stock 5W-40. FFS...getting oil changes right is the lowest possible hanging fruit there is for a shop.
Full Bevo 229.5 list, updated as of June 2020: https://bevo.mercedes-benz.com/bevol..._en.html#close
Mobil 1 FS 0W-30 is listed as meeting MB 229.5 spec. However, this is a) a very different oil than what is available to consumers in the US and b) 229.5 in general is a very broad spec.
Best case scenario, that shop ordered the European version through a commercial vendor and is not completely inept. In any case, however, they were lazy about things as the M156 requires additional consideration.
Bottom line is that this shop took a shortcut and the result is that your engine was exposed to unnecessary risk.
It "still running as it was before the previous 2 oil changes" is NOT an indication a problem. For example, having a lesser weighted oil could have multiplied your wear mileage by 5. If you went 5k miles between changes it's more like 50k miles. Would an engine with 50k miles still run as it did with 5k? Yup, but in theory it sure won't last as long under identical conditions.
No, there's not much you can do other than putting in the proper lubrication and maybe an anti wear additive like what was mentioned.
I don't believe the engine temperatures were actually abnormal, it's just getting hotter out here and I was just being a bit over-concerned (although thankfully I was because I found out about this oil they were using was unacceptable). I contacted the previous owner of the car to see what the normal operating range was since he had it in Florida where it's even more hot than here and the range he said matches the current range it's operating in now.
It is a struggle to find a good shop to take care of my C63 out here in the 'midwest' without having to drive 150 miles to/from Dallas. AMGs and Ms are pretty much unicorns out here. Most shops refuse to even look at my AMG. Hopefully just 2 more months and it'll be on its way back home to Germany.
The TÜV will get you. I had it planned as well. Headlights, tail lights and coding had to be changed. 10% import tax. Shipping another couple grand.
I stopped the research after that and it might be more.
You are better off selling the car and buying one in GER. Best thing is you can get a station wagon C63.
You can get them for Way less as well.
In general it’s not worth it importing a car into Germany unless it’s an Oldtimer where the 10% and other regulations are waived.
And why is everyone all about the wagon AMGs? Am I missing something about it lol?
